[2.7TD] Safe cruise rpm
Results 1 to 2 of 2
Thread: [2.7TD] Safe cruise rpm
    July 8th, 2014
    Poland
    What would be the best safe cruise rpm range (or speed) for my 2.7 TD RRS? Just wondering how long is it possible to maintain fe.3000 rpm without making any harm to the vehicle (2-4 hours?). I guess 2000 is most eco - is this also the best for the car?
    Greets
    SOPHOMORE ROVER garrycol's Avatar
    September 19th, 2013
    Canberra - Australia
    494
    Re: [2.7TD] Safe cruise rpm
    Engine speed will depend on how fast you are driving - the redline is around 4500rpm which probably equates to something like 210kph so normal cruise will be much less - when on the highway my engine rarely gets over 2500rpm.
    Higher speeds where legal might see 3000rpm - certainly that RPM will not heard and I assume you would be fine up to redline.
    Why are you asking - do you want to drive around in lower gears and higher revs - the gearbox will not allow it in normal use. If in Command Shift the gearbox will change up if engine revs get too high.
    Range Rover Sport
    2.7 TDV6
  1. cold start idle rpm & trans fail safe
    By tgoschuetz in forum Range Rover Mark III / L322
    Last Post: October 17th, 2013, 06:47 AM
  2. 2005 range rover driving rpm's are high.. Almost 4000 rpm at 45 mph
    By Jmcgrath in forum Range Rover Mark III / L322
    Last Post: September 7th, 2012, 05:05 PM
  3. Engine cuts out around 1800 RPM, then resumes at 1500 RPM
    By scottt in forum Range Rover Classic
    Last Post: August 25th, 2012, 09:00 PM
  4. Is it safe to hand tight wheel bolts? Or more safe to use impact wench ~!!
    By nysid2007 in forum Range Rover Mark III / L322
    Last Post: November 21st, 2011, 10:08 PM
