1995 Range Rover Classic height?
Results 1 to 15 of 16
Thread: 1995 Range Rover Classic height?
    FRESHMAN ROVER DougG's Avatar
    March 27th, 2007
    Cooperstown, NY
    173
    The owners manual says 72", but my LWB measures at about 69" in height from floor to roof. I just put new springs on and they were stock height springs. What should the height be, and why would I be short?
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 RR HSE
    98 Discovery LE
    Premium Member pl626's Avatar
    July 17th, 2014
    McLean, VA
    1,389
    Re: 1995 Range Rover Classic height?
    Quote Originally Posted by DougG View Post
    Is your EAS intact? I’m guessing not as you mentioned “springs”, so I’m guessing you have coil springs, not the stock airbladder springs that were stock in ‘95.
    Cheers,
    pc
    '95 RRC SWB Alpine White
    '95 RRC LWB Avalon Blue - Sold
    '15 E400 Cabriolet
    '06 E350 Sport (killed by friend's ex)
    '87 HD FLST with '02 Fatboy sheetmetal
    '02 Hobie Getaway
    March 16th, 2013
    Wyoming
    114
    Compare center of hub to fender arch.
    Standard heights are in the Rave manual.
    March 27th, 2007
    Cooperstown, NY
    173
    Quote Originally Posted by Hawk in WY View Post
    I measure 17" from center of hub to fender arch
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 RR HSE
    98 Discovery LE
    March 27th, 2007
    Cooperstown, NY
    173
    Quote Originally Posted by pl626 View Post
    No air springs. Coils
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 RR HSE
    98 Discovery LE
    July 17th, 2014
    McLean, VA
    1,389
    That’s the difference...
    Cheers,
    pc
    '15 E400 Cabriolet
    '02 Hobie Getaway
    March 27th, 2007
    Cooperstown, NY
    173
    Maybe I'll put some spacers in. Just looks a little low visually.
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 RR HSE
    98 Discovery LE
    March 27th, 2007
    Cooperstown, NY
    173
    The owners manual actually says 70.8 inches not 72 like I previously wrote.
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 RR HSE
    98 Discovery LE
    February 18th, 2008
    Portland, Maine
    316
    How are you measuring?
    Any add ons weighing it down?
    Kevin
    88 RRC "Audrey"
    July 17th, 2014
    McLean, VA
    1,389
    With the original EAS, you could adjust the height. Access level was lower, and fully articulated, would have been higher.
    Cheers,
    pc
    '15 E400 Cabriolet
    '02 Hobie Getaway
    March 16th, 2013
    Wyoming
    114
    I don't have access to my data but I recall normal rife height should be 19" front and a bit less rear.
    Sagging Springs.
    March 27th, 2007
    Cooperstown, NY
    173
    Sagging Springs.
    They are brand new springs
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 RR HSE
    98 Discovery LE
    March 16th, 2013
    Wyoming
    114
    Since the vehicle never came with springs, who's to say your new springs are the right choice for your vehicle.
    Maybe not sagging, but not doing what they should do.
    Replace or add a lift kit.
    What size tires are on the vehicle? Identical to factory original?
    Good luck.
    SOPHOMORE ROVER Mikieman's Avatar
    February 19th, 2016
    St louis
    477
    My 92 measures at 72 to 72.5
    im an american i dont speak english
    91 classic..it is now parts
    92 lse... not a bucket of rust
    June 11th, 2016
    northern va 22003
    1,336
    there are a number of coil sizes and manufacturers, all will vary many will offer from standard ride height to a 5 inch lift.
    you may have gotten standard and those may be lower or softer than another manufacturer, thus your difference. two trucks identically fitted
    will never match specs, they will approximate. normally all factory height and weight specs are with full tank of fuel, properly inflated and equal size tires, no load on flat surface, room temperature all fluids filled.
    2k p38 4.6
    95 lwb 4.6
    01 d2 4.0
  1. 1995 Range Rover Classic Red Color Door Light Lens
    By tedasaurus in forum Range Rover Classic
    Last Post: March 19th, 2012, 08:12 PM
  2. 1995 Classic Range Rover Manual
    By aviat in forum Range Rover Classic
    Last Post: March 17th, 2006, 10:43 PM
