94 won’t start after alternator replacement
Results 1 to 3 of 3
Thread: 94 won’t start after alternator replacement
    October 24th, 2009
    61
    1994 4.2 began showing signs of the alternator dying, so I ordered a unit from British Parts of Utah.
    Prior to the replacement, the truck would start every time and there was no odd behavior besides the battery light coming on when idling. I put the battery on the charger and went about replacing the alternator with the new unit. The starter is getting power and will turn the engine over but it won’t start. The only thing that has changed is the alternator. Putting the old one back on and it still won’t start.
    How do I start diagnosing this? Is there something in the general area of the alternator that I could have inadvertently knocked loose?
    I checked the distributor, the cap has no play and the plug wires are all secure. I do not see anything in the area that’s unplugged.
    Thanks in advance!
    February 18th, 2008
    Portland, Maine
    328
    Re: 94 won’t start after alternator replacement
    Check the wires going to the ignition amplifier.
    Also, is your battery light coming on before you attempt to start?
    Kevin
    88 RRC "Audrey"
    October 24th, 2009
    61
    Quote Originally Posted by KK88RRC View Post
    Thanks for the tip, I’ll check that tonight
    The battery light is on as soon as I turn the key to the first position before trying to start.
  1. Range Rover won’t turn over after new battery
    By blakerover in forum Range Rover Mark III / L322
    Last Post: October 30th, 2018, 03:41 PM
  2. Help RR won’t start after gearbox removal
    By Betiteh0777 in forum Range Rover Mark III / L322
    Last Post: June 12th, 2018, 06:02 AM
  3. 2007 RR/SC Won't Start After Alternator Replacement
    By MrRR in forum Range Rover Mark III / L322
    Last Post: October 23rd, 2017, 09:59 AM
