1993 LWB No Spark Past Cap
Results 1 to 4 of 4
Thread: 1993 LWB No Spark Past Cap
    July 26th, 2018
    Asheville, NC
    Randomly died and will not start. I have massive spark coming from the coil into the distributor cap but no spark past there. I've tried swapping the cap and rotor with genuine and after-market parts and still cannot get a spark.
    What am I missing here? Any help is appreciated
    July 21st, 2016
    Tucson, az
    Re: 1993 LWB No Spark Past Cap
    I have a '92 RRC. Have you replaced the Amplifier Module (AM)? I suspect that your year has the same. On my truck that Amplifier Module is attached to the distributor. I know for sure that if the AM is faulty, you will never get spark to a plug.
    April 15th, 2014
    Wimbledon UK
    216
    If the coil makes a spark then all upstream triggering, voltage etc is ok and working.
    If you loose it at distributor cap, it must be cap or rotor. Usually the rotor as it can track down to earth via central spindle.
    Possible to get more than one rotor failed.
    SOPHOMORE ROVER Mikieman's Avatar
    February 19th, 2016
    St louis
    477
    I’m going with the cap and rotor solution as stated by rrLondon
    Replace them first before you change anything else
    and If it doesn’t start after you replace them
    Try adjusting the timing slightly
    im an american i dont speak english
    91 classic..it is now parts
    92 lse... not a bucket of rust
  1. 1995 3.9 no spark past the rotor arm?
    By BostonRover7 in forum Range Rover Classic
    Last Post: June 14th, 2018, 04:03 AM
  2. No spark. No spark . I surrender not. 2001 rangerover
    By jetskilou in forum Range Rover Mark II / P38
    Last Post: February 7th, 2015, 05:54 PM
  3. 1993 Rang Rover LWB Engine has no spark
    By 93roverLWB in forum Range Rover Classic
    Last Post: February 11th, 2012, 07:31 AM
  4. 1993 lwb cranck but dont start no fuel or spark
    By charbel in forum Range Rover Classic
    Last Post: January 3rd, 2012, 06:47 AM
  5. 1993 RANGE ROVER LWB NO SPARK FROM COIL
    By ASHWIN in forum Range Rover Classic
    Last Post: February 16th, 2011, 11:38 PM
