p38 eas system in a classic
Results 1 to 8 of 8
Thread: p38 eas system in a classic
    HSE
    HSE is offline
    SOPHOMORE ROVER HSE's Avatar
    March 7th, 2005
    Port Douglas Tablelands Australia
    388
    Ok, recently bought a 1994 classic to use/fit out for bush camping duties. When I purchased the car the previous owner had ditched the eas for coils. I hate coils!!!! to many years in p38's with eas
    Anyway I went down the track of re-birthing the system. I soon found that many of the components are getting hard to buy through my various suppiers. So i started down the track of using p38 gear, which I had kicking around the workshop.
    I now have the system working well on a p38 valve block and driver module with the ecu still being classic and even a timer delay unit out of a p38!!
    My next move is to mount the whole unit above the cd stacker unit inside the car, behind the RH rear moulding. my reasoning is that the p38 unit is not designed to be submerged like the classic, and I pursonally like electronics out of the dust/mud/sand/water.
    Regards Russell.
    I'd rather push my overheated HSE than drive a tojo
    04' L322 Vogue 22' overfinch wheels
    94' Classic Vogue Plus
    93' Classic LSE
    85' Classic
    58' 88inch series 1 "Stella"
    RX7 13b turbo 450bhp fast
    Range Rover Solutions
    rangeroversolutions.com
    jsp
    jsp is offline
    Premium Member jsp's Avatar
    May 16th, 2005
    South Australia
    1,703
    Re: p38 eas system in a classic
    Quote Originally Posted by HSE
    Regards Russell.
    Do you mean the ecu which sits under the front seat? or do you mean the valve block and driver module?
    Its a fair bit of work to relocate that stuff I guess, and the air intake on the classic is inside the car to ensure the pump doesn't get crud in it. I have had my eas on the classic pretty well underwater twice now (not by choice) and it seems fairly robust. The P38 setup is basically the same, the ECU's are interchangeable from a resetting point of view also, I put the classic ecu into my P38 to reset it via the obd2 - serial cable.
    My only planned upgrade is a pair of cheaper compressors piggy backed to my wearing out compressor (new piston ring about 4 years ago) with a second tank for increased capacity.
    John - South Australia
    1981/1994/2002 Range Rover
    1986 Range Rover Ambulance
    HSE
    HSE is offline
    March 7th, 2005
    388
    Quote Originally Posted by jsp
    Regards Russell.
    yep I'm talking about the eas ecu under the seat still being classic. It's funny the two ecu's (p38/classic) different part numbers but having studied pin placement and operation they are the same. The only real difference in the way the systems work is the pressure switch.
    The relocating is going to involve lengthing the harness and air pipes, not so bad. I'm going to get a piece of harness off a wreck so I'll have the plug at one end to connect to the original driver module and compressor plugs at the chassis. Then do the same at the other end.
    Funny you sould mention the extra tank and compressor, I've got them in the shed waiting for some free time thinking the same thought as you.
    Regards Russell.
    93' Classic LSE
    85' Classic
    August 10th, 2009
    543
    HSE.
    Did you ever consider replacing the P38 gear with the aftermarket Firestone airbag system ? Apparently their available as a total complete replacement for coils !
    Apparently the bellows are designed to support up to 2000kg's per side at maximum inflation pressures, which suits the original design specifications of Rangies.
    Cheerio,
    Vinniman
    '88 Highline
    Perth, W.A.
    April 22nd, 2004
    Asheville, NC
    4,509
    I've got loads of classic parts that nobody seems to want, shoot me an email if you're interested.
    September 27th, 2006
    Paris, FRANCE
    2,491
    Quote Originally Posted by HSE View Post
    Regards Russell.
    Hi Russel,
    May you tell me how you did modify the pressure switch imput to work with P38 components?
    Regards
    Florent
    H
    1997 P38 4.6
    LPG
    SD L322 Rack adapted to P38
    DC5000 EAS Compressor
    Arnott Gen3
    32 inch BF KM2 tires
    Custom Mantec Snorkel
    RPI Sport Exhaust
    H4 Bixenons bulbs
    November 19th, 2007
    Seattle, WA, USA
    47
    Florent, le dernier message dans cette conversation a ete ecrit il y a neuf ans. Bonne chance avec une reponse, mais on ne sait jamais.
    "Americans can always be counted on to do the right thing, once they have exhausted the alternatives." W. Churchill
    April 12th, 2019
    Ok, recently bought a 1994 classic to use/fit out for bush camping duties. When I purchased the car the previous owner had ditched the eas for coils. I hate coils!!!! to many years in p38's with eas <img src="https://www.rangerovers.net/forum/images/smilies/clap.gif" border="0" alt="" title="" class="inlineimg" />
    Regards Russell.
    By timer delay unit are you referring to the AMR1111 relay? Was the p38 part a direct swap or did you have to do some modification?
  1. Feeler:Possibly Selling AC system:1990 Classic
    By HaggardBlaze in forum Range Rover Classic
    Last Post: July 2nd, 2010, 07:21 AM
  2. Nav System
    By BigMack in forum Range Rover Mark II / P38
    Last Post: December 22nd, 2009, 03:04 PM
  3. 87 Classic - stereo sound system upgrade options
    By fermenter in forum Range Rover Classic
    Last Post: March 18th, 2008, 01:53 AM
  4. I need help ....ABS Brake System - 1991 RR Classic
    By JASZD in forum Range Rover Classic
    Last Post: May 25th, 2007, 09:51 PM
  5. How can I tell if Nav system is MK1, 2 or 3?
    By sadcaper in forum Range Rover Mark III / L322
    Last Post: March 16th, 2007, 04:20 PM
