"Door Open" message when door is closed
Results 1 to 9 of 9
Thread: "Door Open" message when door is closed
    June 14th, 2006
    9
    in the driver icon dash area the message pops up saying my driver door is open when in fact it is closed, i usually have to open and close it repeatedly (15-20) times before the light goes away. Any idea on a simple fix?
    is it possible to wire in a resistor somewhere where it will fool the ecu into thinking the doors are always closed?
    also
    something else popped up (market ) something something on the dash and now my computer trip and mpg calculator are all in inactive and replaced with this messsage " ... market not set"
    thanks guys!
    99 callaway niagra grey RR 4.6
    95 Toyota Supra Turbo 550rwhp.
    87 ae86 gts stock
    http://www.douro-oni.com/memberView.cfm?ID=3
    Premium Member paul.adshead's Avatar
    July 26th, 2006
    New Zealand
    1,854
    Re: "Door Open" message when door is closed
    Quote Originally Posted by 8thxSin
    also
    thanks guys!
    I had a similar problem on mine 18 months ago, with the system not picking up the door was open (- when it actually was). It affects more than you think it does:
    - no interior/ footwell/ under-door lights;
    - no alarm triggering for that door;
    - no volumetric alarm active (- it needs to know you've opened the drivers door before enabling this);
    - door locks don't function properly;
    - you can get locked out!! (- I dis-armed the alarm and opened the door; put keys/wallet/mobile on the seat; closed door; then was talking at the back of the car. A minute later the alarm re-locks the car, as it doesn't know a door has been opened and thinks the dis-arming was an accident. Mucho time wasted getting the spare set from home....
    It turns out that in my case, the cause was bad contacts INSIDE the drivers door lock mechanism. I removed the door lock and stripped it down. The connectors that the wiring loom pushes onto, are only a 'finger connection' onto the circuitry, inside the lock unit. On mine, where the 'fingers' contacted the 'circuit board' there was some corrosion and poor connections. I lghtly sand-papered both sides back to clean metal, then carefully 'tinned' each side and soldered across the connection. No problems since. Re-assembling the lock was a bit fiddly though.
    Paul
    '97 4.6 HSE, LPG dual-fuel, Arnott G3s
    Premium Member rtkraken's Avatar
    July 23rd, 2005
    Midcoast Maine USA
    1,111
    Try doing a search on the word "latch". You should find a topic titled "Door Latch" about a year ago that has some details and pics of what you might expect.
    92 RR Classic (retired waiting resto)
    95 RR Classic (sold)
    95 RR P38 4.0 SE (200K)
    96 RR P38 4.0 SE (240K)
    07 RR HSE L322 (110K)
    01 Toyota 4Runner (203K)
    June 14th, 2006
    9
    thanks for the reply guys, so this is what fixed it
    took the door panel off.
    took 220 grit sand paper, sanded all the metal around it.
    sprayed maf air flow sensor degreaser / cleaner all around it
    presto,
    -Curtis
    87 ae86 gts stock
    November 26th, 2005
    Cambridge uk
    355
    Thats who i fixed mine, i removed the door trim and sprayed switch cleaner over the latch and no more trouble
    When a electricle problem crops up it is allways worth trying a quick squirt with switch cleaner . I brought my wife a Saab convertible very cheap becuse none of the window's would work neither would the roof, Saab quoted nearly a £1000 to fix it, I removed the switch pack in the centre consul and spayed it with switch cleaner and every thing worked, I still wonder today if that was what Saab would have done
    1998 Range Rover dse,
    400bhp Sierra Cosworth
    October 22nd, 2005
    Tulsa, OK
    150
    Switch Cleaner
    I am going to tackle this issue Sunday. Does anyone know what "swtich cleaner" is called in the US?
    Thanks,
    Art in San Jose
    '97 4.6 HSE - SOLD 12.22.09
    Black and Tan
    Left Hand Drive
    Riding on Bilsteins, Arnott 3's and Synchrones
    Gasoline Engine
    '00 Mercedes S500 - SOLD 01.15.14
    '09 Audi Q7 - White
    '12 Audi A7 - Black
    June 13th, 2004
    Emu Plains, NSW, Australia
    5,346
    Re: Switch Cleaner
    Quote Originally Posted by ajkennedy
    Thanks,
    Art in San Jose
    I'd suspect the door ajar switch.
    Switch cleaner = contact cleaner
    Ron
    Ron Beckett
    May 22nd, 2018
    Shrewsbury, England
    8
    Re: Switch Cleaner
    My RR is a later L322 but it came up with this message last night and wouldn't change ride height due to the imaginary open door. This morning I did the ECU reboot by disconnecting the battery for 10 minutes and that got rid of the message and the ride height is once again adjustable.
    2008 3.6TDV8 L322
    October 17th, 2017
    East England
    869
    Re: Switch Cleaner
    It may work on an L322 but all disconnecting the battery does on a P38 is cause you to have to reset the windows and sunroof, it doesn't reset any of the ECUs. The L322 uses a similar arrangement with microswitches in the door latch so you're going to be looking at a replacement latch in the near future.
    96 4.6HSE
    98 4.0 Police spec
  1. RF-Door Open Message
    By desertboy in forum Range Rover Mark II / P38
    Last Post: June 23rd, 2011, 07:11 AM
  2. "Crumpled" Drivers side door interior pull handle-how to fix
    By jhepworth in forum Range Rover Mark III / L322
    Last Post: October 21st, 2010, 02:55 PM
  3. Door Lock Failure: Getting the Door Open - the rear door way
    Last Post: March 11th, 2008, 05:34 AM
  4. Alert "Door Open" won't go away and window won't g
    By JF5885477 in forum Range Rover Mark III / L322
    Last Post: December 1st, 2007, 07:04 PM
  5. RF Door Not Closed Message
    By ajkennedy in forum Range Rover Mark II / P38
    Last Post: July 17th, 2006, 12:52 AM
