Knocking noise from crankshaft pully?
Results 1 to 5 of 5
Thread: Knocking noise from crankshaft pully?
    November 23rd, 2005
    Melbourne, VIC, Australia
    Hi All,
    Further to previous post, I have subsequently found that the apparent knocking (it sounds as though someone has a piece of 4"x4" timber inside the motor and is banging it against the block, its no so much metalic in sound but dense, sorry best description I can think of) is coming from the pully attached to the end of the crank, does this have a bearing? I can see oil is seeping past the seal. This so called knocking seems not to be affected by engine rpms. I have checked the flexplate as best I can without removing transmission, I have also carried out sound checks with a screwdriver placed on the heads above each piston (yeah somewhat basic I know), but all seem ok. What else can I do before committing to removing the motor?
    Thanks to those of you who have already responded to previous posts.
    I swore black and blue I wouldnt buy another RR (my fifth) but they are addictive.
    Cheers NAC. P38a 4.6 96
    June 13th, 2004
    Emu Plains, NSW, Australia
    5,346
    Sure sounds like the noise I had with the broken flex plate.
    Can you feel it when you put your hand on the engine.
    Re the crank nose, the main bearing is a couple of inches back at the front face of the block. The oil pump is inside the timing case right behind the oil seal. Could it be making the noise?
    I assume you have checked the pulley for tightness. They have been known to come adrift and destroying the keyway in the cranshaft - but I'm not sure tha this occurs on the V8. It's not uncommon on the 200 and 300TDi diesels.
    Ron
    Ron Beckett
    November 8th, 2004
    Miami,Fl. USA
    938
    How about your timing chain, it connects the crankshaft to the camshaft??
    I never heard of one breaking but they do stretch!!
    ______________
    Range Rover
    L322 4.4 2003
    Ex-P38A 4.0 1997
    Ex-R.R.C. 3.9 1994
    November 23rd, 2005
    Have replaced the oil pump and timing chain to no avail. Noise has not changed. If it is the front crank shaft bearing then obviously motor has to come out? Not much else I can think of. Will keep you posted as to cause.
    Cheers NacsRR
    June 13th, 2004
    5,346
    Did you find out the cause?
    Re the flex plate, I recently found mine was broken again. The break was visible after removing the cover plate off the lower front of the bellhousing.
    Ron
    Ron Beckett
  1. Knocking Noise and Steering Wheel Whistle Noise
    By Jerlew3 in forum Range Rover Sport / L320
    Last Post: July 10th, 2011, 06:25 PM
  2. Knocking noise
    By bigphil in forum Range Rover Mark II / P38
    Last Post: May 29th, 2010, 12:29 AM
  3. Crankshaft vs Cam bearing noise
    By Turpin in forum Range Rover Mark II / P38
    Last Post: February 23rd, 2010, 06:02 PM
  4. knocking noise
    By gx345 in forum Range Rover Mark II / P38
    Last Post: June 7th, 2006, 03:23 AM
  5. Knocking noise in my new 06
    By RR06love in forum Range Rover Mark III / L322
    Last Post: October 7th, 2005, 01:59 PM
