Key won't turn in ignition
Results 1 to 6 of 6
Thread: Key won't turn in ignition
    zem
    zem is offline
    May 22nd, 2005
    Melbourne, Australia
    136
    When I tried to turn the key to start the car it wouldn't move - steering lock seemed to be kicked in. I jiggled both wheel and key and after a few minutes got the key to turn to accessories and hence start.
    Removed key, came back to start car - same thing.
    Is my ignition barrell dying, my key worn or am I not clued up about the secrets of the sterring lock? Need some advice thanks guys.
    1995 4.6 HSE :: 290,000km **New motor @ 280k **
    2.5" sports exhaust (head turning note
    Rhino alloy rack, Dual batteries,Toyo ATR's
    Tartarini injected LPG (72Lt donut)
    Camper Trailer with tinnie on roof
    2004 Yamaha WRF250
    February 18th, 2006
    Winchester VA
    34
    I had a lot of trouble with this same thing when I bought my used 02. Even the dealer couldn't get it to work. I find if I push the key into the barrel about 1/8th to 1/4 inch I could get it to turn and start.
    98 Disco (sold)
    02 HSE
    JUNIOR ROVER jcole21's Avatar
    April 26th, 2006
    678
    Resolution that worked for me / ignition won't turn
    Turn the turn signal left and right a couple of times and should be good.
    JCole
    2010 RRSC current
    2000 4.6 HSE prior
    January 27th, 2006
    Laredo, Tx
    300
    It seems there was a thread some time ago about using even a drill to loosen the internals. A search would be helpful.
    JUNIOR ROVER LEBoyd's Avatar
    July 5th, 2009
    Houston, TX
    888
    Re: Key won't turn in ignition
    So I have this issue this evening. The key won't turn. The steering wheel is not locked. The door locks work, the lights all seem to work and no messages before turning it off.
    Anyone have any ideas???
    2004 L322, 265/50R20 Yokohama tires. "Mrs. Jones" ("We've got a thing going on")
    November 20th, 2011
    bexhill on sea / uk
    11
    Hello, I have exactly same problem with my 1998 4.6 LE. Just finished a rebuild of the air valve block and riding nicely ,now having a job to start car as key wont turn. I have sprayed silicon into lock barrel but not much difference.Anyone know if its possible to strip ignition barrel and fix it. seems like something is worn and jamming up. John
  1. Key won't turn in ignition
    By 07RRBlackSC in forum Range Rover Mark III / L322
    Last Post: October 16th, 2017, 01:41 PM
  2. ignition key will not turn
    By detroitbrit in forum Range Rover Mark III / L322
    Last Post: December 26th, 2015, 10:12 PM
  3. key won't turn in ignition.
    By scottuf in forum Range Rover Mark III / L322
    Last Post: September 3rd, 2011, 07:58 AM
  4. Ignition key won't fully turn
    By jimmyjam in forum Range Rover Classic
    Last Post: June 9th, 2011, 06:12 PM
  5. clicking noise when i turn ignition off
    By s1ggm in forum Range Rover Sport / L320
    Last Post: January 19th, 2011, 04:05 AM
