98 P38 condensation drain plug drivers side keeps blocking
Results 1 to 9 of 9
Thread: 98 P38 condensation drain plug drivers side keeps blocking
    September 18th, 2014
    Louisiana
    17
    My 98 P38 drain plug for the AC unit keeps getting stopped up. It floods the drivers side and runs out the door after soaking the carpet.
    I thought about putting a small pipe inside the plug, about 1.5 inch long just to keep the drain open. Has anyone found a better way to keep the drain the drain from flooding the floor?
    October 17th, 2017
    East England
    777
    Re: 98 P38 condensation drain plug drivers side keeps blocki
    Is it the drain getting blocked or is it that the flexi hose isn't seated properly so the water is getting out before it gets to the drain? Pull the centre console side panel off and make sure it is properly seated.
    96 4.6HSE
    98 4.0 Police spec
    June 11th, 2016
    northern va 22003
    1,366
    dust and pollen is pulled in by the fans past the dust filter in the center cowling, (looks like a piece of foam) this eventually settles at the bottom of the hvac box, when the a/c condensates, the accumulated dust and pollen become mud. as it leaves the hvac box it tends to clog the drain.
    with vehicle cold, crawl under then looking up to the transmission tunnel around the bellhousing you should find the drains one on each side of transmission bell housing.
    from factory they had a tip with a 4 way cut, remove and clean but if you want to leave them off permanently it does not hurt (it is supposed to keep bees and other small insects from crawling in there). if they have been removed you are somewhat ahead of the game, then go back inside and with a blow gun blow out the drain tube (not to the inside of hvac box).
    repeat at least twice a year based on driving conditions specially if very dusty. the inside is accessed as Richard G is suggesting.
    2k p38 4.6
    95 lwb 4.6
    01 d2 4.0
    Louisiana
    17
    I stick a probe into the drain plug and the water comes pouring out underneath. The cross cut at the opening keeps sticking together and sealing the drain plug. It's like I need to put some navel jelly on it to keep it from sticking closed
    Louisiana
    17
    Pure clean water comes out, no milky mucus, the very tip seals so thinly but causes a mess in the cabin floor
    May 28th, 2018
    SW London
    85
    Maybe stick an open cable grommet in the four petals, stops them closing and means you have the option of reversing the mod/ changing the size of grommet. I haven't done this myself, just strikes me as do-able
    1998 Defender 50th 4.0L V8 Auto
    1998 Range Rover 50th 4.6L V8 Auto
    Toylander Series 2A
    Previously
    1980 SIII 2.25 petrol
    1997 200 Tdi CSW
    June 11th, 2016
    northern va 22003
    1,366
    Quote Originally Posted by romanrob View Post
    why do that when you can remove them.
    2k p38 4.6
    95 lwb 4.6
    01 d2 4.0
    Louisiana
    17
    I've decided to try a 6" Tye Wrap, as we called it at BellSouth. It's also called a Cable Tye in some areas.
    It's a strap that tyes to itself to hold things almost forever.
    I'm going to to insert the head of the tye wrap just into the drain plug. The drain plug openings are still soft and the"Tye" is very lightweight. The wind during traveling should keep the 6" Tye wiggleing enough to maintain a small opening in the plug when needed.
    Romanrod had the first idea if his cable "Grommet" is the same thing as my "Tye Wrap."
    June 11th, 2016
    northern va 22003
    1,366
    a simple solution is being over complicated, best of luck.
    2k p38 4.6
    95 lwb 4.6
    01 d2 4.0
  1. Blocking protection problem – front wipers
    By RRPhil in forum Range Rover Mark III / L322
    Last Post: March 5th, 2018, 02:15 AM
  2. Replies: 7
    Last Post: September 29th, 2015, 11:23 AM
  3. EGR valve removal / blocking
    By P38-Mart in forum Range Rover Mark II / P38
    Last Post: November 26th, 2013, 04:25 PM
  4. Blocking off oil cooler ports.
    By oryx in forum Range Rover Classic
    Last Post: October 31st, 2012, 10:42 AM
