New remote key fob. - Page 2
Results 16 to 25 of 25
Thread: New remote key fob.
    October 17th, 2017
    East England
    874
    Re: New remote key fob.
    Should be as long as Australian ones use 433 MHz, it's only the 315 MHz ones used in the US and Japan that are no longer available.
    96 4.6HSE
    98 4.0 Police spec
    April 2nd, 2019
    23
    Be aware that not all Australian P38s were converted to 433MHz. There is one sitting in my garage which is still 315Mhz.
    Aftert buying a new key from LR. With a 5 week wait to get it, finding it didn’t work, taking it back, to have LR then tell me that they had no record of my car being upgraded etc. etc. Very frustrating.
    Les in Wales is your best answer for a 315 key.
    October 17th, 2017
    East England
    874
    If your car has a 315 MHz fob then it is probably an import from Japan as, according to Wiki, Australia uses 433 MHz for RAKE LPDs. Les is Wales is your ONLY option for 315 MHz fobs.
    96 4.6HSE
    98 4.0 Police spec
    April 2nd, 2019
    23
    Australian delivered as a new car with all paperwork and service records from new, including JLR build and sale information.
    June 2nd, 2019
    . I have just joined the group, we are able to supply you with 100% compatible Key Fobs for your P38. There are various options available to you. 1) send us your Key & we will extract the code from your fob & manufacture a new Fob with blade cut to suit your car. 2) we can send you a capture device so that you can capture your key code for us. Send the device back to us along with a few good pictures of both sides of your key blade ( we can usually reproduce the blade using pictures, this is done on a state of the art CNC key cutting machine), but don't be concerned , we supply you with an extra blank blade in case we didn't get the cutting right from the photographs you can get the second blade cut by a local automotive locksmith).
    We are able to supply both 433 Mhz & 315Mhz fobs.
    If you need any more info feel free to message me.
  8. #21
    June 2nd, 2019
    Just to clear up a bit of a myth regarding P38 Key Fobs.
    Your landrover may tell you that all four keys available have already been issued therefore you will need to buy a complete new lockset & have the BECM reprogrammed, alternatively they may inform you that only Key one is now available ( all others have been discontinued). If you purchase a second No. 1 key you might find you have 2 x No. 1 Fobs, both can't work at the same time on your car ( it will only recognise one key at a time)
    As a P38 specialist garage we can supply "Aftermark" 100% compatible Key Fobs for the P38, you can have Keys 1,2,3 or 4.
    This blows the myth, that you can only have one issue of each key, actually if you were totally paranoid we could supply ² of each ( 100 of each if you really wanted them.
    The replacement keys do everything the OEM Fobs can do, they can do even more on older cars, they have "smart Sync" , this means you can resume the Fib to the car WITHOUT GOING THROUGH THE DRIVERS DOOR LOCK.
  9. #22
    June 2nd, 2019
    Contact Iain @ We-R-RangeRiver-P38s
    Facebook page.
  10. #23
    27,613
    Quote Originally Posted by Pierre3 View Post
    I am left with only one working key fob and that one is a bit dodgy
    There are fob rebuild parts available, new battery cover with Oring. New button cover
  11. #24
    February 5th, 2019
    San Jose, CA
    33
    Do you have any other contact info besides Facebook? Interested in purchasing a key or 2
    2001 4.6 HSE
  12. #25
    January 13th, 2017
    Long Island
    125
    Quote Originally Posted by kultur View Post
    Try reading post #2 in this thread.
    2001 P38 4.6 HSE, Kent Green/Light Stone
  1. Low Battery display from Key FOB - but no Key FOB in use...
    By stevecollin in forum Range Rover Mark II / P38
    Last Post: October 7th, 2018, 11:58 PM
  2. new key fob remote from dealership only?
    By DarkPanacea in forum Range Rover Mark II / P38
    Last Post: April 25th, 2015, 08:56 PM
  3. Old Key FOB Won't Unlock Doors, New Key FOB Won't Start Car... Ideas?
    By WBlackstone in forum Range Rover Mark III / L322
    Last Post: March 9th, 2013, 04:08 PM
  4. Transferring key fob internals to replacement fob
    By wiggy in forum Range Rover Mark II / P38
    Last Post: April 29th, 2009, 10:49 AM
  5. Key / FOB question - Have key blade (that was part of FOB)
    By lui2001 in forum Range Rover Mark II / P38
    Last Post: March 19th, 2009, 05:01 PM
