P38 Amplifier
Results 1 to 9 of 9
Thread: P38 Amplifier
    February 16th, 2019
    4
    P38 Amplifier
    Hey guys, i've had my P38 for quite a while now. It has the original speakers (no Harman&Kardon) and it has an aftermarket head unit. Now i want to replace the speakers because they really have seen better times. Anyways i am wondering if it is even necessary for me to get a new amplifier or if the amplifiers that are installed at each door are good enough for the new speakers. If i should install a new one, has anyone of you guys figured out a good place to put it?
    SOPHOMORE ROVER xrav22's Avatar
    December 15th, 2014
    Southern Ca.
    335
    Re: P38 Amplifier
    Find a lower milage p38 and replace the speakers. I have the HK system and it still sounds great. It was broken for years so I got lucky.
    I have a LR bass out but it still sounds great.
    1997 Range Rover 4.6 HSE
    1985 Chevy Corvette 5.7 TPI
    4x SrS reset with nano
    P0183 changed fuel temp sensor OK
    P1179 cleaned maf with maf cleaner OK
    P1314 reset CEL OK (was going thru large puddles when CEL went on).
    Service Engine reset/Adaptive values reset
    October 17th, 2017
    East England
    735
    Re: P38 Amplifier
    Door amps are perfectly good enough. I had one door speaker with a seized coil and the other had a split cone. Replaced them with JBL 600C speakers, made a hell of a difference.
    96 4.6HSE
    98 4.0 Police spec
    May 10th, 2016
    Surrey, BC, Canada
    192
    Since most after market car stereos usually have fairly substantial amps I wounder how this works with the door amps?
    Moderator RRToadHall's Avatar
    27,549
    Re: P38 Amplifier
    Quote Originally Posted by Twist View Post
    what year and model of P38? there are vast differences between model years and trim levels. Also your location for market differences
    ~ Maharishi Mahesh Yogi~
    December 15th, 2014
    Southern Ca.
    335
    Re: P38 Amplifier
    If you are using an aftermarket with amps you need one of these. Works great with HK system.
    November 10th, 2016
    Tasmania
    245
    Re: P38 Amplifier
    Quote Originally Posted by xrav22 View Post
    Click image for larger version.
    No you don't, just don't turn your radio up too high.
    27,549
    Re: P38 Amplifier
    Reinhoud actually is correct
    besides aftermarket stuff always looks like hack job.
    November 10th, 2016
    Tasmania
    245
    Re: P38 Amplifier
    You want as least as possible stuff in your audio system, keep it "clean" and simpel, + to + and - to -.
    Treble and bass on 0, leave it like that for a while, so you get used to it, and the audio system needs to break in too, believe it or not, and your radio sounds the best!
    I've got an Alpine head unit with the stock Harman Kardon, and I'm impressed how a stock system can sound, especially when I keep in mind it's 23 years old.
    Mine didn't come with a sub, but even without a sub there's enough low, how much low does the stock sub add?
  1. P38 2001 sound system amplifier
    By Vdb in forum Range Rover Mark II / P38
    Last Post: September 1st, 2016, 05:25 AM
  2. P38 problems, amplifier
    By toni_ in forum Range Rover Mark II / P38
    Last Post: March 28th, 2015, 11:09 AM
  3. bmw e46/4 harman kardon amplifier in p38
    By Fred in forum Range Rover Mark II / P38
    Last Post: October 20th, 2014, 01:21 PM
