Nanocom "engine torque fault" on 1995 Auto 4.6 Gearbox - Page 2
Results 16 to 17 of 17
Thread: Nanocom "engine torque fault" on 1995 Auto 4.6 Gearbox
    February 17th, 2019
    36
    And the chuff is fixed too. Coil pack.
    Running like a Bentley now. Smooth engine and imperceptible gear changes. The coils were the original 1995 and show no outward signs of problems, plugs looked good too with all pretty much the same appearance.
    February 17th, 2019
    36
    I meant the roughness is fixed too by changing the coil pack.
  1. Gearbox Fault and Nanocom returns no codes
    By ukko in forum Range Rover Mark II / P38
    Last Post: September 4th, 2018, 07:58 AM
  2. Auto Gearbox and Torque Converter Issues
    By simmov8 in forum Range Rover Mark III / L322
    Last Post: November 13th, 2014, 09:42 PM
  3. Auto Gearbox fluid replacement on L322 TD6 or M57 and GM gearbox
    By L322_expert in forum Range Rover Mark III / L322
    Last Post: May 28th, 2013, 06:03 AM
  4. Engine Won't Start - "Gearbox Fault" & "ABS Fault"
    By jmason in forum Range Rover Mark II / P38
    Last Post: March 12th, 2013, 02:55 PM
  5. 4.6 AUTO GEARBOX 1995: ECU AND VALVE BLOCK INSIDE OR OUTSIDE
    By sebastian in forum Range Rover Mark II / P38
    Last Post: June 5th, 2006, 10:09 AM
