P38 Front Air Suspension problem
Results 1 to 11 of 11
Thread: P38 Front Air Suspension problem
    April 8th, 2019
    Gladstone, Queensland, Australia
    The story starts with a failure of the crack angle sensor on my 2000 4.6 HSE that required a tow to my local mechanic (on a tilt tray truck).
    Three weeks later the mechanic had obtained the correct spare and fitted it. Once again the engine was operational, but now I had an issue with the air suspension.
    The rear air bags pumped up correctly, but the front air bags would not.
    I had an EASBuddy plug which I tried, but that didn't fix the problem.
    I also tried running the engine with a door open to "charge" the air reservoir,but that didn't help either.
    Any Suggestions?
    27,613
    Re: P38 Front Air Suspension problem
    HUH, what is crack angle sensor?
    Do you mean crank position sensor? there are only 2 GEMS and Bosch
    as far as as your EASBuddy it only clears the code it does not repair anything or tell you anything. Get yourself REAL diagnostic gear and toss EAS"buddy" in the Rubbish bin, it is useless
    April 24th, 2006
    Northern California
    860
    Sure it won't repair anything but even more expensive readers don't give you terribly useful info. It resets the ECU which is far from useless after you have repaired the leak. After all, the by far most common cause of an EAS "35 max" shutdown is a leak causing the compressor to take too long to reach height. Fix the leak, reset with the Buddy, and off you go. Calling it useless......is useless.
    '99 Range Rover HSE
    '02 Audi S6
    SENIOR ROVER Bolt's Avatar
    September 6th, 2012
    At large on the US West Coast
    1,411
    Instead of beating him up about his diagnostic gear, why not read the post and apply logic to it?
    We all also knew he meant the CPS.........
    If the mechanic who installed the new CPS raised the front of the truck too high, possibly he caused a line to come off a bag, or possibly he even damaged one of the front bags or height sensors? Check the plugs and wiring to the front height sensors, and give the air lines and bags as good a look as possible.
    A type specific diagnostic like a Nano would be of assistance as well. If you post your location, someone may be nearby and could help?
    1952 Austin Champ (Hawaii)
    1953 Austin Champ (Australia)
    1985 Classic w/ Tdi300 (Australia)
    2002 4.6 HSE, White "Bolt" Hawaii Daily driver. Now the "Boat Car" here on the West Coast
    2002 4.6 HSE Borrego Yellow "Digby" Wife has absconded with Borrego as the Dog Taxi
    October 17th, 2017
    East England
    874
    I would also recommend the Nanocom but for just the EAS you don't need to go that far. Buy or make up a cable (see http://www.rswsolutions.com/index.ph...s-serial-cable) and download the free EASUnlock software (http://www.rswsolutions.com/index.ph...d=53&Itemid=56) and you have all the diagnostics for the EAS you will ever need. As said, the EASBuddy only resets any faults but if you haven't found what caused the fault it will only occur again.
    96 4.6HSE
    98 4.0 Police spec
    June 11th, 2016
    northern va 22003
    1,410
    open a door while the compressor builds air, (some 10 minutes or so). then close the door to allow for self levelling, if all goes well the system should have enough pressure to allow suspension to raise almost evenly.
    this should allow volume and pressure on your favor to detect if a leak is preventing inflation.
    2k p38 4.6
    95 lwb 4.6
    01 d2 4.0
    April 8th, 2019
    I think I see the problem!
    April 8th, 2019
    I think I see the problem.....
    could it it have been winching onto a tilt tray recovery truck?
    September 6th, 2012
    1,411
    Yep, there's your problem!
    No, this was not done by the tow truck.
    As I first suspected, the mechanic raised the front to access the CPS and unseated the bag, then cluelessly lowered the chassis on the crimped bag. Easy enough fix, but I would ask that they eat the cost of the new bag since they caused the problem.
    April 24th, 2006
    Northern California
    860
    You might not need a new airbag if it is just pulled off. Just lift the body with a floor jack (wheels on the ground) high enough to partially extended the bag. Work it back into place. Start it with the door open until the compressor shut off, close door and let it lift off the jack as the bag inflates.
    Also, the shop had to have heard a loud bang when the bag came off and released its air. Nice of them to ignore it and send home with you. Wouldn't go back there if it was me.
    '99 Range Rover HSE
    '02 Audi S6
    June 11th, 2016
    northern va 22003
    1,410
    use soapy water to help seat the bag in place. it has ridges similar to the beads of a tire, thus it must slip in place. raise the chassis a few inches leaving axle on the ground, apply soapy water liberally, work bag on bead, with chassis supported inflate suspension and it should be it.
    2k p38 4.6
    95 lwb 4.6
    01 d2 4.0
  1. Front drivers side air suspension bag released air
    By rosrooster in forum Range Rover Mark III / L322
    Last Post: August 31st, 2016, 06:03 AM
  2. Front air suspension problem
    By OLLIECAT in forum Range Rover Mark III / L322
    Last Post: August 28th, 2015, 07:00 PM
  3. 2003 Range Rover, front air suspension problem
    By rstasi in forum Range Rover Mark III / L322
    Last Post: November 18th, 2014, 06:07 PM
  4. Bilstein Air Suspension Shocks vs Non-Air Suspension Shocks
    By brody in forum Range Rover Classic
    Last Post: November 9th, 2012, 10:47 AM
  5. Replies: 3
    Last Post: September 6th, 2012, 09:31 PM
