P38 Brake Problem
Results 1 to 3 of 3
Thread: P38 Brake Problem
    FRESHMAN ROVER Pulaski's Avatar
    September 5th, 2017
    Whidbey Island, Washington
    21
    P38 Brake Problem
    Hello everyone
    I apologies if this sort of thread has been made before.
    I have a 2001 Range Rover with pretty mushy breaks. The other day I decided to take the front tires of to check the pads. When I did, they all still had plenty of padding left. So then I checked the back, and it was the same. I checked the brake fluid and it was right in between the MAX and MIN. line. I am a little confused on what is happening. Help?
    Thanks in advance,
    Best Regards,
    Pulaski
    27,609
    Re: P38 Brake Problem
    SOunds like your accumulator may be failing. do you hear or feel the brake pump running almost every time you step on the brake pedal?
    September 5th, 2017
    21
    Problem solved! I let the vehicle sit for about a week or so, and after that the brakes were way better. Thanks for the help.
    Best Regards,
    Gabriel Bozeman
  1. p38 brake problem. no brake at startup. advice anyone?
    By knutharald in forum Range Rover Mark II / P38
    Last Post: July 1st, 2014, 01:47 AM
  2. Brake Problem, spongy and the "brake light" comes on every so often....
    By HANSGRUBER85 in forum Range Rover Mark II / P38
    Last Post: July 24th, 2013, 07:53 PM
  3. Brake Problem / Brembo Brake Pad pins stuck
    By armydiver in forum Range Rover Mark III / L322
    Last Post: April 27th, 2013, 11:57 AM
  4. p38 hse brake problem
    By HSE in forum Range Rover Mark II / P38
    Last Post: November 27th, 2007, 01:16 PM
  5. p38 brake problem
    By vande_v in forum Range Rover Mark II / P38
    Last Post: April 1st, 2007, 03:07 PM
