2001 P38 Fuel Pump / Location / Specs
Results 1 to 9 of 9
Thread: 2001 P38 Fuel Pump / Location / Specs
    January 3rd, 2018
    San Francisco Bay Area
    13
    Hello. I have a 2001 Range Rover 4.6 SE which needs the fuel pump replaced. 1. Am trying to determine specific location, how to access, etc...
    1. Must I cut a hole in the floor of the vehicle? 2. If so, would anyone know the specs of the specific location? 3. Must the tank be dropped? Thank you.
    June 11th, 2016
    northern va 22003
    1,400
    re: 2001 P38 Fuel Pump / Location / Specs
    drop the fuel tank, much easier than to cut a hole thru the body.
    27,609
    Detailed steps are in the RAVE workshop manual with pictures. The positive side to dropping the tank is you can inspect for corrosion and make sure your brake lines are in perfect shape.
    SENIOR ROVER Bolt's Avatar
    September 6th, 2012
    At large on the US West Coast
    1,403
    Having done this twice, on the 99 and the 02, I would say drop the tank.
    Be sure to siphon or pump out as much fuel as possible first, and a floor jack with a 1 ft square of plywood or a transmission jack will make the job a breeze.
    Once you start hacking holes in the back with grinders or saws, you will take the very real chance of cutting something you do not want to, starting a fire, or worse!
    If you were gonna cut anyway, use a large hole saw, and then enlarge the circular hole so that an marine plastic inspection port (Pyhi) can be installed, and properly bedded with sealant, so no exhaust gasses, water or critters can get in.
    Doing a proper job of hole cutting will take way longer to do, and in the end, if you put in a quality replacement pump, you will never have to drop the tank again.
    1952 Austin Champ (Hawaii)
    1953 Austin Champ (Australia)
    1985 Classic w/ Tdi300 (Australia)
    2002 4.6 HSE, White "Bolt" Hawaii Daily driver. Now the "Boat Car" here on the West Coast
    2002 4.6 HSE Borrego Yellow "Digby" Wife has absconded with Borrego as the Dog Taxi
    June 4th, 2007
    Belgium
    1,184
    If you have access to a ramp or lift, dropping the tank is ot too bad. If not, an access hole is the way to go IMHO. The car I last did this on already had the rear seats removed, which made things even easier. You can drill out the spotwelds on the edge of the seatbox (front and side) and carefully grind through one other side, leaving the fourth as a hinge so you can fold it back afterwards. Spotwelds can be replaced with rivets or screws, a bit of sealant or tape will close the seams.
    Filip
    SOPHOMORE ROVER xrav22's Avatar
    December 15th, 2014
    Southern Ca.
    346
    2001 P38 Fuel Pump / Location / Specs-capture.jpg2001 P38 Fuel Pump / Location / Specs-captu.jpg2001 P38 Fuel Pump / Location / Specs-capt.jpg
    1997 Range Rover 4.6 HSE
    1985 Chevy Corvette 5.7 TPI
    4x SrS reset with nano
    P0183 changed fuel temp sensor OK
    P1179 cleaned maf with maf cleaner OK
    P1314 reset CEL OK (was going thru large puddles when CEL went on).
    Service Engine reset/Adaptive values reset
    P39
    P39 is offline
    FRESHMAN ROVER P39's Avatar
    September 12th, 2017
    West Midlands, UK
    41
    I accessed mine through the floor - each to their own, but I now have access to pipes and electrical connectors forever - more details on my blog here
    I used a hole saw to cut all 4 corners of the access hole - tape the hole saw with insulation tape generously a few millimeters up its shank - that way when it bursts through the metal, it won't suddenly drop through and start drilling important bits - note I packed the hole saw with washers so the centre drill only just protrudes, again, there's less chance of drilling things on the blind side.
    2001 P38 Fuel Pump / Location / Specs-dsc_0017.jpg
    I cut the piece out with an oscillating multi tool - really controllable and no sparks.
    2001 P38 Fuel Pump / Location / Specs-dsc_0020.jpg
    2001 P38 Fuel Pump / Location / Specs-dsc_0021.jpg
    My aperture has a permanent frame with a removable lid - it just makes access easier in the future and it's neat - the hole is rubber lined, and the lid has a gasket so there's no fume or damp issues.
    2001 P38 Fuel Pump / Location / Specs-dsc_0042.jpg
    2001 P38 Fuel Pump / Location / Specs-dsc_0043.jpg
    I've tried to include pictures for you, but this habitually fails with me, so if you can't see them, PM me and I'll send them over.
    Attached Thumbnails Attached Thumbnails 2001 P38 Fuel Pump / Location / Specs-dsc_0020.jpg   2001 P38 Fuel Pump / Location / Specs-dsc_0043.jpg
    Range Rover P38 1996 4.6 HSE Gems - some of my modifications here
    Range Rover P38 6X4 camper - very slowly progressing on a 1995 4.6 HSE
    Freelander 2 (LR2) - I know, but its brilliant!
    Range Rover Classic 88" 4 wheel steer - now with happy new owner in Guernsey
    Range Rover Classic 6x4 camper - alas also now gone to new home
    and a lot more been and gone!
    October 17th, 2017
    East England
    868
    Biggest problem with cutting a hole is that it allows you to get to the fuel pump but not the pipes. I've had two cars now that have developed leaks because the pipes had rusted above the tank so it has had to be dropped anyway to change them. You may as well do it properly once rather than having to do it a second time.
    96 4.6HSE
    98 4.0 Police spec
    27,609
    Re: 2001 P38 Fuel Pump / Location / Specs
    Dang good way to try out your replacement insurance. Do it the proper way by dropping the tank there is zero risk of toasting your Rover.
  1. Bosch 66156 Fuel Pump is Thor Fuel Pump Assembly WFX101390
    By beowulf in forum Range Rover Mark II / P38
    Last Post: October 29th, 2018, 07:40 PM
  2. Fuel schrader valve / fuel rail valve 2001 4.6 P38 Bosh
    By mdzoidberg in forum Range Rover Mark II / P38
    Last Post: May 6th, 2015, 05:41 PM
  3. fuel pump location and access
    By 06HSEROVER in forum Range Rover Mark III / L322
    Last Post: July 31st, 2013, 06:33 AM
  4. Fuel pump location
    By RobertB in forum Range Rover Mark III / L322
    Last Post: January 29th, 2013, 07:30 PM
  5. Looking for a ground location on fuel pump
    By magoguy in forum Range Rover Classic
    Last Post: August 23rd, 2005, 05:37 AM
