Harmon Karmon Subwoofer Blown! - Page 5
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 67 of 67
Thread: Harmon Karmon Subwoofer Blown!
  1. #61
    June 7th, 2009
    Auckland, NZ
    468
    Re: Harmon Karmon Subwoofer Blown!
    DD audio has just released a 6.5 sub. Dual 4 ohm voice coils.
    http://www.ddaudio.com/mobile-audio/spe ... eries.aspx
  3. #62
    January 30th, 2011
    SATX -- Alamo City
    74
    Having just purchased a used sub enclosure sans speakers to replace the missing sub setup in my '02, I am subscribing.
  4. #63
    April 13th, 2014
    Colorado Springs, Colorado USA
    315
    FYI my dual subs were toast. I upgraded my front and rear speakers and had the 4 door 6.5 woofers left over. I broke off the metal tabs,drilled new holes in the edges. Pulled off the foam rings and installed them in the box. Sounds good so far. And when those die I'll use the other two. Then when those die I'll buy the JL ones. Budget rover work.....ha!
    2002 HSE 4.6
    P38 black/black Audi heater core installed, double din radio installed,
    PAC Steering wheel controls and backup camera installed.
  6. #64
    October 26th, 2015
    Washington D.C.
    40
    I just replaced my subs with two "Pyramid WX65X 6-1/2" White Poly Woofer Part # 290-270". $10.83 each at PartsExpress.com.
    Easiest way I found is to remove the entire sub box, then unbolt it in half. The short wire harness from the sub amp makes connecting tough otherwise. They sound excellent!
  7. #65
    April 13th, 2014
    315
    Nice! I've heard good things about those speakers from the Jeep guys
    Lots of them in use in outdoor..Jeepin conditions. Durable and cheap
    2002 HSE 4.6
  8. #66
    January 13th, 2017
    Long Island
    124
    Quote Originally Posted by l888apex View Post
    Thanks to this post I have restored great sound to my otherwise stock Alpine H/K hi line system. I kept replacing my woofers but they were all similarly old and didn't last long. I don't blast music. I purchased these speakers (I think they were about $24 for the pair) and was pleased to find they fit perfectly in the stock enclosure. Even the screw holes lined up. I split the enclosure, detached the woofer amp from the stock speakers and simply installed the new speakers. I need to find a more permanent way of hanging the woofer amp from the speakers but after putting the woofer enclosure back together I fired it up and it sounds great. The whole job took me about half an hour. The DSP amp seems happy and these speakers should last longer than the car. The wires from the woofer amp are too short to mount the amp to the bottom of the enclosure and I'm too lazy to solder extensions. I'm thinking some serious two sided tape or contact cement to hang the amp under the speaker like it was originally. So far very happy. I'm not sure if woofer wires are "phased" and no terminals are marked so hoping I did it right.
    Harmon Karmon Subwoofer Blown!-img_6625.jpgHarmon Karmon Subwoofer Blown!-img_6624.jpg
    2001 P38 4.6 HSE, Kent Green/Light Stone
  9. #67
    December 6th, 2013
    Walvis Bay, Namibia
    29
    You can just take an AA battery and connect wires to the speaker briefly, the cone will either move forwards or backwards and you can phase your subs together. I speak under correction but I think if the cone moves forwards then the polarity is correct.
    '01 4.6 Vogue, Epsom Green/Walnut. a.k.a. Roary
  1. Harmon/Kardon Subwoofer Question
    By tanarover in forum Range Rover Mark II / P38
    Last Post: May 7th, 2012, 04:59 AM
  2. Best place to sell a harmon kardon logic 7 subwoofer from 03
    By abrown3mtg in forum Range Rover Mark III / L322
    Last Post: July 11th, 2011, 02:04 PM
  3. my subwoofer is blown -- need a DIY for a 2003 HSE
    By miami m3 in forum Range Rover Mark III / L322
    Last Post: November 30th, 2009, 09:59 AM
  4. Subwoofer In Passenger Door Blown - Warranty?
    By SSIIICK in forum Range Rover Mark III / L322
    Last Post: January 15th, 2008, 04:40 PM
  5. Blown subwoofer replacement question
    Last Post: February 20th, 2006, 07:29 PM
