Rear hatch will not open, no power to lock
Results 1 to 15 of 15
Thread: Rear hatch will not open, no power to lock
    February 1st, 2009
    Brevard, NC. USA (Sunderland, UK)
    7
    I have a 97 4.6. Rear hatch does not open, There is no power at actuator . At the same time when I lock the door with key fob the front passenger door does not lock. I have it from a good source that the power to the hatch runs through the front passenger door actuator. Does anyone have experience with this problem? Thanks in advance.
    97 4.6 HSE
    2000 Chevy 3500 Dually
    OCS
    OCS is offline
    FRESHMAN ROVER OCS's Avatar
    February 18th, 2009
    Czech Republic
    215
    Re: Rear hatch will not open, no power to lock
    The good source is right.
    For awhile, my passenger central was bad, so I had to lock/unlock the door manually. When locked, the rear did not work. When unlocked, it did. Fixing the passenger's central fixed the whole thing. Good fun of the classical Land Rover kind.
    SENIOR ROVER q-rover's Avatar
    August 14th, 2007
    Norway
    1,052
    As above.
    Should work if you can get the passenger doorlock in the unlocked position.
    Lock isn't difficult to change, just a bit awkward if your R handed.
    The most difficult part is not tearing the foam doorliner.
    1998 Autobiography 4.6 V8 of course
    August 12th, 2007
    hamilton, canada
    155
    Mine does this when the dog locks just the passenger door after the key is out of the ignition. Try starting the car and then pull the drivers door lock up and down a couple of times, then lock and unlock with the key fob buttons with it still in the ignition. Go for a drive, then get out and see if the locks work right.
    97 4.6HSE- 200,000Km RBLT- Trans,Transfercase
    EAS and Brakes
    February 1st, 2009
    7
    Door will super lock and unlock with FOB, just doesn't lock on first push but hatch is dead whether doors locked or not. I will try locking by hand just on the chance I can get it to work until I can change it. Does anybody have any tips on taking door panel off, don't want to break anything. Thanks for the replies and will post anything I find out that will help others.
    97 4.6 HSE
    August 14th, 2007
    Norway
    1,052
    Removing a door panel is simple.
    Remove 2 screws under/ through the grab handle. Hidden by plastic caps.
    Remove the screw behind the inside door latch. Hold th latch in the open position.
    Remove the plastic surround with a bit of fiddling twisting and turning.
    Pull/ prise off the speaker cover in the corner.
    Remove hex head screw.
    Using something that won't damage the paint (I use a plastic wedge) get it
    between the door and doorcard and strat prizing it away. It is now only held on
    by plastic studs. Go all the way around untill it is loose. When pulling off beware
    of any eventual speaker wires that need disconnecting.
    It is possibly a good idea to have som new plastic studs ready for refitting as some
    invariably get bent/ broken/ or otherwise become no longer reuseable. Don't know the
    part no. off hand though, sorry.
    Fitting is just as simple but in reverse order.
    February 1st, 2009
    7
    Thanks for the info, I'll take a shot at it soon if it ever stops raining.
    97 4.6 HSE
    February 1st, 2009
    7
    Update on rear hatch lock, A relay or something looking like one came loose inside passenger front door and got in the way of window gearing, when window was lowered it cut the wire that feeds power to rear hatch button, spliced it back together and all is well. Hope this may help somebody.
    97 4.6 HSE
    December 21st, 2011
    NH
    181
    01 4.6 US spec... rear hatch is dead, no power or sound. Doors all fine, rear wiper works too! Help!!!
    June 11th, 2016
    northern va 22003
    1,405
    check your fuses, it is controlled by the becm.
    2k p38 4.6
    95 lwb 4.6
    01 d2 4.0
    October 17th, 2017
    East England
    871
    BeCM isn't involved in the rear hatch at all, power comes from F15 (20A), to the motor in the lower tailgate, from there goes to the pushbutton and the other side of the pushbutton is grounded via the front right door latch. If the front right door is unlocked, ground is sent to the pushbutton, if it is locked, then it isn't. Both wires go through a connector behind the trim in the right side of the boot, the power will be on the Purple wire while the ground return from teh door latch will be on the Green/Red wire.
    96 4.6HSE
    98 4.0 Police spec
    January 5th, 2013
    Colorado
    30
    Had the same thing recently, sounds odd but hold down the actuator rear hatch button while you thump below it on the tailgate with your fist.
    Quote Originally Posted by 30thAnnP38 View Post
    October 17th, 2017
    East England
    871
    Having to give it a thump is usually a sign that the spring has rusted. The bits of rust stop the button from being pushed in far enough to operate the microswitches inside. Repeatedly poking the button also works and once you get the tailgate open you can take the pushbutton out, take it apart and clear out the rust.
    96 4.6HSE
    98 4.0 Police spec
    December 21st, 2011
    NH
    181
    Wowww.... smacked below button and voila!!! Thxxxxx
    October 17th, 2017
    East England
    871
    You've got the rusty spring problem then. Very, very simple to fix.
    96 4.6HSE
    98 4.0 Police spec
  1. Replies: 3
    Last Post: March 2nd, 2016, 09:42 AM
  2. Key will open the doors and the hatch but not...
    By sanmigmike in forum Range Rover Classic
    Last Post: August 25th, 2010, 11:00 PM
  3. Electrical Issue (Rear Hatch Button Doesnt work, doors lock)
    By smartalek in forum Range Rover Mark II / P38
    Last Post: October 11th, 2009, 12:38 AM
  4. Gas Cap Access Hatch won't open....
    By Jgunnerh3 in forum Range Rover Mark II / P38
    Last Post: February 20th, 2009, 10:44 AM
  5. Fuse for hatch lock
    By Flyboy in forum Range Rover Mark II / P38
    Last Post: January 16th, 2006, 05:32 PM
