Door micro switch bypass? - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
Thread: Door micro switch bypass?
  1. #31
    October 17th, 2017
    East England
    783
    Re: Door micro switch bypass?
    Quote Originally Posted by nosync View Post
    I had the same issue: took off the driver door’s panel, found the purple/white wire coming out of the switch, cut and isolated with electric tape.
    Are you saying you deliberately cut the Purple/White wire? Why? That's the wire that goes to the door ajar switch so if it is cut you'll get no interior lights and, as you say, the possibility of locking the keys in the car. If the switch has failed so it thinks the door is permanently open, replace it.
    96 4.6HSE
    98 4.0 Police spec
  3. #32
    FRESHMAN ROVER nosync's Avatar
    January 20th, 2017
    AZ
    26
    you need be careful cutting wires. why is your fob dead? you know AB sells rebuild kits with new battery cover and Oring since our remotes are water proof, there is also the new button cover. so again, why is your fob dead? Is one of the battery terminals broken off? that can be rigged
    what ever reason it dead you can order a new fob case off eBay and sacrifice you old case and move your key an its spring along with remote board and the transponder chip over to the new case.
    I am glad my fob IS dead, some whiz kids with a laptop, copied my fob signal as I was looking my other car at a restaurant, got in, took some valuables and were kind enough to lock it back again.
    I only use the old fashioned key on all my cars now .
  4. #33
    January 20th, 2017
    AZ
    26
    Quote Originally Posted by Richard_G View Post
    Yes indeed, I live in rural AZ, and it was the logical choice, I have a bigger fish to fry.
  6. #34
    March 28th, 2010
    COLOMBO, SRI LANKA
    822
    Quote Originally Posted by scimitargtc View Post
    go inexpensive and buy an MGF door lock 2nd hand for £15-£20 then u can play with the one you take out to get it work when the replacement gives out
    Can I know the MGF part no, please?
    thanks.
    P38 - 1997 2.5 DSE
    CLASSIC - 1982 ,2.4 VM DIESEL(In complete Project-sold)
    TOYOTA CORSA -1998, 1.5 TURBO DIESEL (sold)
    Haven't heard of Murphy's Law, go buy a RANGE ROVER.!
  7. #35
    October 17th, 2017
    East England
    783
    Depending on whether you are RHD or LHD you could be very lucky. See https://rimmerbros.com/Item--i-GRID019022), LHD ones are on clearance at very much reduced prices. The only difference between an MGF latch and a P38 latch is the cable to the interior door handle is a different length and has a different fitting at the handle end so you just swap over your P38 cable. I bought the brand new LH latch for a LHD MGF (FQJ102292PMA) and swapped the motors and microswitches into my RHD RH latch.
    96 4.6HSE
    98 4.0 Police spec
  8. #36
    March 28th, 2010
    COLOMBO, SRI LANKA
    822
    Thanks. Unfortunately my car is RHD and I want is LH front latch. Anyway, if I get MGF front left one of LHD car, it should be okay, I guess.
    P38 - 1997 2.5 DSE
  9. #37
    October 17th, 2017
    East England
    783
    It will have more microswitches than you need (3 the same as the RH latch on a RHD car) so you may need to modify the wiring slightly but it will work.
    96 4.6HSE
    98 4.0 Police spec
  10. #38
    March 28th, 2010
    COLOMBO, SRI LANKA
    822
    Thanks. Let me order n see.
    P38 - 1997 2.5 DSE
  1. Power fold mirrors micro switch
    By Av_Dave in forum Range Rover Mark III / L322
    Last Post: January 15th, 2019, 08:33 AM
  2. Driver's Door Switch Pack - help
    By JamesL in forum Range Rover Mark III / L322
    Last Post: May 11th, 2013, 12:40 PM
  3. Door open switch
    By Dannyboy in forum Range Rover Mark II / P38
    Last Post: August 4th, 2012, 03:02 AM
  4. Right front door dome light switch??
    Last Post: January 4th, 2007, 09:22 AM
  5. Replacing the fuel door switch
    By stank in forum Range Rover Mark II / P38
    Last Post: April 23rd, 2005, 10:27 PM
