water leak I had a leak on one of the hoses so took it off replaced clip and refitted
Results 1 to 6 of 6
Thread: water leak I had a leak on one of the hoses so took it off replaced clip and refitted
    December 20th, 2014
    7
    I refilled with water no water leaked out so started engine no problems drove home 6 miles heard bubbling from header tank removed cap water came out so let it cool down for 1 hr then topped up ran again for a couple of mins but had to put more water in
    27,613
    Re: water leak I had a leak on one of the hoses so took it off replaced clip and refi
    OKay... and...
    Sounds like you haven't purged the system of air so you will be overheating until you do.
    December 29th, 2005
    Swindon, Wiltshire, UK
    4,126
    I would think that you need to run the system with the correct amount of proper coolant in the system, rather than just water. It has a higher boiling point than just water, so it shouldn't boil over. Also will stop it from all freezing solid in the winter, and has corrosion inhibitors in it to stop the internals of the engine from rusting
    http://p38webshop.co.uk
    December 20th, 2014
    7
    Ok will try and do that I will open top of radiator hose I thought it might of been head gasket but no water in oil or on cap on top of engine
    December 29th, 2005
    4,126
    Make sure the bleed hose from the top of the radiator to the header tank is clear by blowing through it, as this is how the system purges air
    December 20th, 2014
    7
    Ok will do thanks
  1. Water leak
    By timc in forum Range Rover Mark III / L322
    Last Post: March 16th, 2011, 01:39 PM
  2. Replaced water pump, checked hoses still problems.
    By ZLandrum in forum Range Rover Classic
    Last Post: May 28th, 2010, 03:03 PM
  3. water leak
    By simontaxi in forum Range Rover Mark II / P38
    Last Post: September 22nd, 2007, 03:24 AM
  4. Water Leak??
    By Dusan33 in forum Range Rover Sport / L320
    Last Post: August 20th, 2007, 05:00 PM
  5. water leak and more
    By Matt1399 in forum Range Rover Mark II / P38
    Last Post: September 8th, 2005, 11:07 AM
