P38 SRS Reset with paper clip?
Results 1 to 11 of 11
Thread: P38 SRS Reset with paper clip?
    January 5th, 2013
    Long Beach CA
    25
    Has anyone ever done this and or had any success on a reset without a diag tool?
    Hi,
    Contrary to popular belief, I've just found out that you CAN reset the
    dashboard SRS light yourself - no Rover dealer required !
    All you need is a paper-clip.
    Directly under the steering wheel, just under the bottom of the dash board,
    above the pedals, you can see a wide grey connector. A few inches towards
    the drivers door from this, is a horizontal 2-pin yellow connector - with
    nothing connected to it. Bend your paper-clip into a U shape, and stick the
    ends into the 2-pin yellow connector, so shorting the pins.
    Turn on the ignition, and the SRS light will illuminate for a few seconds,
    and then go out.
    Now pull out your paperclip (but not right out), so breaking the link.
    After a couple more seconds, the SRS light will illuminate again.
    Now stick the paper clip back in, making the link again, and after a couple
    of seconds, the SRS light will blink twice.
    Remove the paper-clip, and then switch off the ignition.
    You have to do this all fairly quickly - you only get a few seconds between
    each step. Because you can't see the yellow connector and the SRS light at
    the same time, it's really a two-person job.
    That resets the SRS system - next time you start the car, the lamp will be
    off - obviously this only applies if you have no fault ! If there is a
    fault, the light will illuminate again. I know I had no fault, because the
    light illuminated (and then stayed illuminated) when my alternator died.
    It is tricky but it is 100% correct (stolen from Rover by an enthusiast)
    Let us know how you get on.
    cheers.........Dave
    http://community.preloved.co.uk/foru...ing-light.html
    27,613
    Re: P38 SRS Reset with paper clip?
    Quote Originally Posted by dbiles View Post
    There is a huge difference between a Rover and a Range Rover. In addition there is no reference in your link as to which models this procedure covers. It'd be great if this would work on a P38 but I am fairly sure we have no grey connector or open yellow connector as referenced in the link.
    December 29th, 2005
    Swindon, Wiltshire, UK
    4,126
    Definitely haven't seen a random yellow connector in the dash on any P38 I've worked on.... in theory, it may work as I think it *could* be the same ECU - but it would be a case of having to try and find the wiring diagram for the Rover, and working out what pins you are actually shorting - and then see what they correspond to on the P38.. which if they aren't normally connected, then you have to take most of the centre console apart to get to the ECU in the first place.
    Oh, and if Rover are anything like Range Rover, then the electrical manual probably will be pretty sketch on wiring for the SRS system. In fact, I'm 90% sure RAVE doesn't have ANY wiring diagrams for the SRS wiring - so it would be a case of tracing it all manually...
    Interesting to see if it does work, if someone has the time and inclination to investigate it (and has access to a Rover to try it... the link suggested something about a Rover 600 in a couple of posts above, so I assume that it *may* be aimed at that type of vehicle...
    http://p38webshop.co.uk
    27,613
    Quote Originally Posted by marty_nz View Post
    RAVE ETM for Bosch rigs has an SRS section with schematics. However when I went through it jut now I didn;t see any terminated or spare connections.
    December 29th, 2005
    4,126
    Ahh, I do seem to remember seeing something like that before - hence the 90%!!, I looked in the 1997 ETM for GEMS vehicles - as the Bosch ones self-clear on power on if the fault has been rectified
    Pretty sure the ECU is different too now - after a bit of searching on google.
    Banned
    March 10th, 2014
    208
    Can confirm the above from Marty and RRTH: This is sadly a myth; The earliest P38s had the TRW SRS system just like the ROVER 800 but which can NOT be re-set other than via the diagnostics connector. Before this Rover used several different airbag manufacturers/modules (which had this 'spare reset connector'). The best use for a paperclip and a P38 is just to keep all your invoices/bills in one place... sorry.
    August 21st, 2004
    Cambridgeshire, UK
    454
    Quote Originally Posted by P38baffled View Post
    . . . . . . The best use for a paperclip and a P38 is just to keep all your invoices/bills in one place... sorry.
    That'll be one sizeable paper clip then
    2001 Vogue . . . . . . and, yes, I do own the road!
    September 18th, 2014
    Louisiana
    17
    Does the SRS dash light come on the 98 Range Rover due to mileage, like the 82,500 Service Engine Light?
    August 6th, 2014
    Fife
    42
    Just had a look and no yellow connector, unscrewed the 4 screws holding said panel on and hey presto there it is.
    1998 4.6 hse UK model.
    im not going anywhere near it with a paperclip tho.
    June 13th, 2006
    Kuala Lumpur
    1,851
    Hi
    The SRS light does not come on ever based on mileage. It should come on during start up and extinguish shortly after turning the ignition switch to position 2, this indicates self test of the system was successful.
    Best regards
    Jos
    1995 RR 4.0 SE
    December 29th, 2005
    4,126
    Quote Originally Posted by ffourphantom View Post
    Picture speaks a thousand words...
    Or as the kids are saying these days... Pics or it didn't happen
  1. SRS light on --- then off w/o reset
    By spikemd in forum Range Rover Mark II / P38
    Last Post: June 10th, 2018, 08:35 AM
  2. Early P38 SRS (Airbag) fault
    By _ASH_ in forum Range Rover Mark II / P38
    Last Post: December 9th, 2013, 04:11 AM
  3. SRS Airbag light reset -- HELP
    By powerfiend in forum Range Rover Mark III / L322
    Last Post: March 2nd, 2010, 12:15 AM
  4. T4/Rovacom near swindon uk ?? (SRS reset)
    By Snake110 in forum Range Rover Mark II / P38
    Last Post: August 20th, 2009, 03:15 PM
  5. P38 SRS Diganostics
    By kyle h. in forum Diagnostic Equipment
    Last Post: June 4th, 2009, 11:34 AM
