Thanks.
Results 1 to 5 of 5
Thread: Thanks.
    May 16th, 2014
    Ely. Cambs. UK
    37
    Thanks.
    I just like to say a big thanks to Gilbertd, for calling in this afternoon and sorting out my EAS.
    Was good to put a face to a name. Hopefully catch up next weekend at the LRO show.
    Many, many thanks again. Phil.
    Banned
    March 31st, 2014
    Peterborough, UK
    3,952
    Re: Thanks.
    No problem Phil, just fortunate I was going to be your way today anyway. Here's a thread with the dimensions for the calibrating blocks https://www.rangerovers.net/forum/7-r...on-blocks.html so you (we) can calibrate the system and stop it from getting it's knickers in a knot again.
    May 16th, 2014
    Ely. Cambs. UK
    37
    Re: Thanks.
    They look easy enough to do !!!
    Phil.
    May 13th, 2006
    Hong Kong
    192
    Re: Thanks.
    I made a set and spent a whole afternoon crawling around under the car checking & rechecking heights with Faultmate, only to be told that this method was only effective for use with TestBook and that measuring from the centre of the hub to the wheel arch was the "only" way to calibrate without TestBook. Obviously not the case judging from this thread. I wish I could have been there to see it in person.
    Out of interest, how long did it take?
    December 29th, 2005
    Swindon, Wiltshire, UK
    4,125
    Re: Thanks.
    The 'official' Land Rover calibration blocks can only be used with Testbook - as it doesn't do height for every setting. From what I understand there is a low set and a higher (maybe standard height) set of blocks, which Testbook reads the height values from. It then uses some internal algorithm to work out what the height setting should be for the rest of the heights and then programs these into the EAS ECU.
    Any other method of diagnostics which will give you raw height sensor data for every height (nanocom, faultmate, EAS Unlock software, and I presume others like Lynx and Hawkeye) you can make up a set of blocks like in that thread for EACH height, then read the actual values, to then program them back to the EAS ECU.
    I made up a set of blocks myself - only to find after cutting them all down that the supplier of the Delrin rod I used sent me 20mm diameter stuff, not 30mm like I had ordered.. and since I had already cut it up, I wasn't able to return it They still work, but at some point I will probably look at re-doing them in the 30mm diameter so they fit properly in the bump stops.
    Marty
    http://p38webshop.co.uk
