Starting to concern me..
Results 1 to 8 of 8
Thread: Starting to concern me..
    April 25th, 2007
    South Coast.. UK
    264
    Had this problem once or twice but now its happened twice in 2 days.
    Basically i go to start it and the ignition comes on, turn key to start and... nothing.. doesnt even try to turn over. If you turn the ignition off then back on it fires up like nothings happened..
    Im a little worried that one day it just wont turn over. This a problem?
    '02 MK3 TD6 HSE - Awesome!
    '95 Vauxhall Calibra Turbo - Project
    '95 P38 4.6 HSE - Gone
    Premium Member kmagnuss's Avatar
    May 10th, 2006
    Sarasota, FL
    3,622
    Mine has done that before. Turned out to be the battery cables had gotten loose. Loose enough to pull right off.
    Crooked Rod Charters www.crookedrod.com
    Tarpon... everything else is just bait
    April 25th, 2007
    South Coast.. UK
    264
    Quote Originally Posted by kmagnuss
    thats interesting as when i got the thing they couldnt get it started and messed around with the battery, will get the cover off and check it out
    February 14th, 2007
    Burbank, CA
    533
    Funny, I was just thinking about this. I have had the same issue, not really a problem though.
    I was thinking mine had to do with the brake safety switch.
    Can anybody start their truck without a foot on the brake? I believe this isn't supposed to happen, but mine does it. Can't remember if my last 4.0 did this or not.
    2000 4.6 HSE - 3" OME 764f/781r, GB dual cardon
    92 Classic - SOLD
    98 4.0 - OME coil conversion 4" lift, 265/75/R16, Dual cardon, 5150 LT shocks, Cb - SOLD
    98 4.0 - DESTROYED
    95 Defender 90 - SOLD
    27,613
    My 4.6 has done both of these. The first time my buggy didn't respond to the key my guts sank to the floor boards. Of course this was just after it's third visit to the shop for EAS work. "What next?" I thought. It's done it three times now. I just chalk it up to Lord Lucas.
    I can start mine without my foot on the brake. I just can't shift unless braking.
    April 16th, 2007
    WEST CHESTER, PA
    8
    ME NEGATIVE BATTERY END WAS LOOSE AND CORRODED A FEW WEEKS AGO. I JUST PUT A WHOLE NEW CABLE AND END ($25) AND NO MORE PROBLEMS. I NEVER HAVE TO PRESS THE BRAKES TO START MY ROVER.
    DANNY
    July 5th, 2005
    Lincolnshire,UK
    123
    I get the same problem if I insert key turn to poss III to quickly....Methinks its because the key hasnt had time to sync with the system yet so engine is still immobilised
    April 25th, 2007
    South Coast.. UK
    264
    if that were the case you would get engine disabled in the message center
    the key transmits the signal as soon as its inserted to its unlikely you can turn it fast enough for that to be the case
  1. 2011 RRS Supercharged suspension/steering concern
    By SantoriniRRS in forum Range Rover Sport / L320
    Last Post: December 2nd, 2010, 01:20 PM
  2. Goodyear Eagle RSA Tires / 104 Load Rating Concern
    By cliffk in forum Range Rover Mark III / L322
    Last Post: September 2nd, 2010, 10:15 PM
  3. 22" wheel concern
    By jay50 in forum Range Rover Sport / L320
    Last Post: July 12th, 2010, 06:26 PM
  4. Cold = Easy Starting / Hot = Poor Starting
    By glaesemann in forum Range Rover Mark II / P38
    Last Post: December 2nd, 2008, 07:42 PM
  5. Coolant concern
    By North in forum Range Rover Mark II / P38
    Last Post: March 15th, 2006, 06:10 AM
