Minimum Height Clearance Required For 05 RR
Results 1 to 2 of 2
Thread: Minimum Height Clearance Required For 05 RR
    Guest
    Does anybody know what the minimum clearance is for an 05 RR with 19' stock wheels when the EAS is in the normal [not crawl] height mode? I drive in/out of parking garages all the time, but I would prefer not to have to lower the EAS everytime. I have driven in a garage where the sign said "max clearance 6'3" with the sunroof open. There was not too much room between the RR and the roof, but I cleared it without lowering the EAS. But I Sometimes forget that the 05 has the antenna unit mounted on the back that'll probably require an extra inch or two to clear from the roof.
    Anybody have any experience or input to share? Thanks.
    FOUNDING MEMBER codynt's Avatar
    December 13th, 2004
    San Francisco, CA
    446
    Check under the driver's side sunvisor. If I remember correctly, I think it's 6'4"
  1. Want more clearance
    By minaz in forum Range Rover Classic
    Last Post: August 30th, 2009, 04:10 PM
  2. RRS SC Front Rotor Minimum thickness?
    By FASN8N in forum Range Rover Sport / L320
    Last Post: December 31st, 2008, 08:32 AM
  3. Minimum rim size on TDV8 (brembo)
    By Airscape in forum Range Rover Sport / L320
    Last Post: November 17th, 2008, 08:20 AM
  4. RRS vs LR3 ground clearance.
    By Leo in forum Range Rover Sport / L320
    Last Post: February 22nd, 2008, 10:31 AM
  5. Suspension Clearance too low????
    By Rovers4life in forum Range Rover Sport / L320
    Last Post: March 1st, 2007, 05:46 PM
