2003 rr monitor problems
Results 1 to 6 of 6
Thread: 2003 rr monitor problems
    Guest
    my display monitor is stuck in vertical hold position. is there anyway to fix this problem or does anyone know the actual part that solves this
    October 8th, 2004
    Chalmette, LA
    146
    Never heard of that one before. However, the monitor on my 03' sometimes goes blank but has always turned back on after a few minutes. Perhaps your problem may self correct also.
    Together we achieve the extraordinary!! 2007 RRS Supercharged Black on Black
    May 1st, 2005
    Scranton, PA
    7
    Quote Originally Posted by roveurboat
    Yup, my 2000 740iL had this same odd behaviour, sometimes it would just freak out and go blank, then it would come back eventually.
    April 12th, 2005
    UK
    136
    This may sound off the wall but try removing the CD changer and the Sat nav disc, then replace.
    Sometimes this action helps to reset a stuck gizmo.
    2007 Range Rover Vogue SE TDV8 : Stornoway/Jet, RSE DVD, Hybrid TV, Privacy Glass
    November 17th, 2004
    7
    thanks but its still ugly
    May 1st, 2004
    nr Cambridge, UK
    155
    There's a 30Amp fuse in position 11 I think, but can't remember exactly. If you pull this for 30 sec and re-insert you will reset the satnav and comms systems. Sorry if I sound a bit vaugue on position. I'll have a look tomorrow in the light and see if I can give you an exact no.
    Steve
  1. RANGE ROVER from HELL!!!! 2003 that keeps having problems
    By jgjk in forum Range Rover Mark III / L322
    Last Post: April 5th, 2011, 10:16 AM
  2. 2003-2005 headrest monitor DVD headrests
    By ambishop in forum Range Rover Mark III / L322
    Last Post: April 28th, 2010, 05:42 PM
  3. 2003 hse monitor not showing anything its just blank
    By akondor in forum Range Rover Mark III / L322
    Last Post: March 19th, 2010, 04:01 PM
  4. dec 2003 RR problems i have
    By livste in forum Range Rover Mark III / L322
    Last Post: January 18th, 2009, 04:32 PM
  5. HELP 2003 RR with problems
    By jblieb in forum Range Rover Mark III / L322
    Last Post: June 11th, 2007, 02:37 PM
