P0442 "Evaporative Emission System Leak Detected (small leak)"
Results 1 to 3 of 3
Thread: P0442 "Evaporative Emission System Leak Detected (small leak)"
    FRESHMAN ROVER Gorf's Avatar
    October 17th, 2011
    Maple Valley, Washington
    129
    So I threw a "Service Engine Soon" light yesterday. Pulled out the scanner and got P0442 "Evaporative Emission System Leak Detected (small leak)".
    P0442 "Evaporative Emission System Leak Detected (small leak)"-lr_fault_code.jpg
    There appears to be a couple other threads on the forum with similar issues but no followup:
    https://www.rangerovers.net/forum/6-r...-detected.html
    https://www.rangerovers.net/forum/6-r...got-p0442.html
    So I thought I would start a thread, and first ask: Does anyone have any thoughts on where this leak is mostly likely occurring?
    Second, I thought that if nothing came up here in the forums I could at least use the thread as an anchor to document what I find in my particular case.
    So, any thoughts?
    '11 RR SC LUX
    Gorf
    October 17th, 2011
    129
    Re: P0442 "Evaporative Emission System Leak Detected (small leak)"
    Ok so, first follow up. Biggs Automotive in Bellevue kindly threw the Range Rover on their system. They identified it as something to do with vapor leakage from the fuel system. We removed the gas cap and took a peek and did find some grime around the filler that might have been preventing a good seal. It might just be time for a new cap. Other than that, we talked about a pressure blow-off valve on the tank that might be a little faulty and then a motor that controls something in or around the tank that can allow some leakage. Biggs cleared the faults out of the system, cleaned up the gas filler inlet, and sent me on my way to see anything pops up again.
    tl;dr probably leaky gas cap, waiting to see if the error comes back.
    '11 RR SC LUX
    Gorf
    September 22nd, 2008
    2,252
    This has been covered here I think... I vaguely remember having to replace some valve towards the front of the motor when my car kept throwing this code. It has something to do with regulating gas pressure in the fuel system... I think. Regardless I replaced the part and it hasn't been an issue since.
  1. P0441 Code Evaporative Emission System Incorrect Purge Flow
    By mark1107 in forum Range Rover Sport / L320
    Last Post: August 11th, 2016, 06:22 AM
  2. Evaporative Emission Control System Leak Detected
    By andrewva26 in forum Range Rover Mark III / L322
    Last Post: July 19th, 2011, 02:47 PM
  3. "Fuel Injection/Emission failure" warning light
    By NKG in forum Range Rover Classic
    Last Post: August 1st, 2010, 11:51 PM
  4. EAS "Leak-Down" problem... Ideas?
    By sroeb in forum Range Rover Mark II / P38
    Last Post: November 28th, 2009, 08:05 AM
  5. "System Too Lean" 0171 and 0174 Codes....
    By hende052 in forum Range Rover Mark III / L322
    Last Post: February 22nd, 2008, 04:29 PM
