Is this a shady dealer tactic or an honest battery failure? - Page 2
Results 16 to 26 of 26
Thread: Is this a shady dealer tactic or an honest battery failure?
    May 19th, 2014
    Long Island, NY
    367
    Re: Is this a shady dealer tactic or an honest battery failu
    Quote Originally Posted by MichalNY View Post
    I see you are on Long Island. Where have you had your car serviced? I might go to another dealership for my extended warranty repairs...this was just not cool
    I do most of my repairs myself, although I would not rebuild an engine or transmission. Everything else I'll do/try.
    If I need professional service, I take my Range Rovers to Scott Dalton who owns Expedition Imports in Smithtown off Middle Country Rd (Rte. 25). (631) 780-6035
    2006 Range Rover HSE 4.4L AJ41
    2004 Range Rover HSE 4.4L M62
    December 29th, 2016
    Brighton, CO
    Just food for thought. We replaced our original battery about a year ago, on a 2011RR. I would have the shop check the alternator and water pump. Both also recently gave out.
    June 18th, 2019
    Just changed the alternator and battery on my 2003 Range Rover. Now when I hit the gas Trans Failure and battery light and others pop up. Srems like the car doesn't want to go. Has anyone had this issue? What is recommended and do I have a battery reset button I need to hit?
    FRESHMAN ROVER BillConn's Avatar
    February 4th, 2018
    Portland, OR
    91
    Quote Originally Posted by DBHJONBOY View Post
    Probably should start a new thread for this one.
    April 19th, 2017
    Hawaii
    Batteries have the uncanny ( engineered ) ability to last as long as the label states if your lucky . A five year battery rarely lasts more than 5 years . Eight years is a long time for a battery to last in a Rover . I work on them and own them . You can put jumper cables from another car or battery on the battery points in the engine compartment and then carefully disconnect the battery . Put in the new battery and your good to go !
  8. #21
    August 25th, 2018
    Warwick, NY
    8 years of life for a battery in the northeast? I’d say you’re a lucky man!
  9. #22
    FRESHMAN ROVER georgekale's Avatar
    June 28th, 2015
    Illinios
    7
    Have you ever installed a battery in Range Rover L322? It not easy to get the battery out. 1. Put the hood in service position.( disconnect hood stays) 2. Remove 60 lb. heavy battery. 3. Clean cables, install new heavy battery. 4. Program all lost accessory program. 5. reinstall hood stays and road-test.
    I think there more than 20 mins.Is this a shady dealer tactic or an honest battery failure?-lr-fix-.jpg
  10. #23
    FRESHMAN ROVER buba's Avatar
    March 27th, 2015
    Europa
    131
    itis a havy batery, so to save my back ( 69 ), i made this helper.
    Is this a shady dealer tactic or an honest battery failure?-20180520_162705.jpg
    Is this a shady dealer tactic or an honest battery failure?-20180520_162641.jpg
    2012 TDV8 Black Edition
  11. #24
    October 2nd, 2013
    Grapevine TX
    203
    That's a cool idea.
    FWIW, I've found it's easier to stand on a small platform/bench alongside the right front fender when replacing the battery.
    This method saves one's lower back and it's easier to pull upwards using your knees to lift the battery onto the right strut mount area in one swift movement.
    I once had a neighbor spend an hour trying to figure out how to remove the battery on a MY2010 L322 before they stopped by and asked for some help.
    They almost kicked their car once I had it removed within ten minutes (but knowing "how" is what a dealer charges for (book time) not how long it takes
    If it normally takes a trained JLR tech longer than 30 mins all in, they're costing themselves $$$ earning potential. There are, however, always exceptions given the occasional mis-step uploading any needed software post install.
    What the dealer charges a customer (book time) is another story, of course.
    I'm a little surprised that the OP's dealer GM hasn't/didn't at least try to work with the OP on the battery replacement book charge in order to retain their future business.
    I guess everyone can be ripped off (or feel ripped off) at least once before taking their business elsewhere - in which case, both lose as the OP has an extended warranty and a used vehicle likely needing further repair = future revenue opportunities for someone [else?].
    Rob
  12. #25
    April 22nd, 2019
    NYC / Long Island
    39
    As an update....when the service advisor called me to pick up the car, he said the tech "already put a used battery in" so they managed to get it done without additional charges. So far so good, but Im already looking at Duralast Platinum from AutoZone
  13. #26
    January 29th, 2007
    Toronto,Canada
    1,716
    Glad they did that except that battery could fail also. I agree that someone/thing let the battery discharge badly which an older one just cannot take. But I do have a general question about which year a battery change requires reprogramming the car by the dealer.
    2008 Alaska white SC with 128,000 mi. latest diff folly. 2004 Epson green 275k kms now for sale. also 1952 Hough payloader 1959 Nuffield 4DM
    2000 kent green 4.0 SE sold
