04 L322 Air Suspension Inactive after sitting
Results 1 to 4 of 4
Thread: 04 L322 Air Suspension Inactive after sitting
    March 2nd, 2016
    Canada
    Hi Guys,
    I have a 2004 Range Rover, I've read a bunch of posts yet I just can't figure out what the issue with my suspension is. My car was vandalized while it wasn't insured and it sat with no battery connected for a good 8 months. I got it painted and realized that the suspension was completely decompressed. I tried doing the "turning steering wheel lock to lock" method but it didn't fix the issue. The instrument panel where i can raise or lower the SUV has no power at all and I keep getting an "air suspension inactive" light. I checked the 15 amp fuse in the glove compartment and it was good I put in a new one just incase. Any idea how I can get it back up and get the system power again? I did notice my tires have low air pressure too I don't know if that would make a difference but I have to get the rusted valve caps off and fill them up still. I hope you guys can help me, I've already had to pay so much just to get the vandalism taken care of.
    April 16th, 2018
    Boulder, Co
    27
    Re: 04 L322 Air Suspension Inactive after sitting
    You will need to have the trouble codes / fault memory cleared from the air suspension control module and then the air compressor should kick back on and inflate your air springs. When you have a hard fault stored it will shut down the system. You will need a scan tool that can communicate with the air suspension control module to do this.
    FRESHMAN ROVER Rovah's Avatar
    January 24th, 2013
    Ladue, MO
    134
    Agree with the post above. You need a tool to read the faults first and then clear. On a side note a rodent could have chewed electrical wire on the suspension height wire or valve block while the vehicle sat for 8 months. I personally experienced that from purchasing one from auction where it sat for a while.
    2005 RR HSE 4.4 Java Black
    2004 RR HSE 4.4 Zambezi Silver
    MrE
    MrE is offline
    March 4th, 2018
    Boise Idaho
    44
    Quote Originally Posted by Rovah View Post
    You can get the tool from Amazon for a 2003-2005 Range Rover for somewhere around $25. Search for "bmw scanner version 1.4.0". I had to solder in a jumper wire to make it work, but many references to the work around on the web.
    2004 Range Rover HSE
    1986 Newell Motorhome w/2001 Cummins ISM
