2004 Range Rover Headlights Upgrade (to '06 lights) - anyone
Results 1 to 4 of 4
Thread: 2004 Range Rover Headlights Upgrade (to '06 lights) - anyone
    April 15th, 2011
    10
    Hi,
    I just picked up a set of headlights from a 2006 Range Rover under the impression that these would fit the 2004 Model. Looking at the layout of the lights, it doesn't look like it's a bolt on.
    I was wondering if anyone has done this? If so, is it a direct bolt on or it requires Fender/Bumper modification?
    SOPHOMORE ROVER W84IT's Avatar
    June 29th, 2010
    Indio, CA
    417
    Re: 2004 Range Rover Headlights Upgrade (to '06 lights) - an
    It's not a direct fit...you will need more than just the headlights to do this conversion...do a search and you should find the thread that discusses this in detail along with the parts you will need.
    Ray
    Current:
    2013 Range Rover L405 HSE(Fuji White with Almond Interior)
    Previous:
    2010 Range Rover L322 HSE(Alaska White with Jet Interior)
    2005 Range Rover L322 HSE LUX(Zambezi Silver with Charcoal Interior)
    2005 Range Rover L322 HSE(Zambezi Silver with Charcoal Interior)
    2004 Range Rover L322 HSE(Adriatic Blue with Sand Interior)
    SENIOR ROVER Stevemfr's Avatar
    September 27th, 2004
    strasbourg, france
    1,410
    There's actually quite a bit of info on this conversion right here on the board: SEARCH
    To help you along a little, in addition to the headlights you'll need:
    - an 06-09 bumper and spoiler pieces
    - a grill
    - fog lights and trim rings
    - light mount bar
    - you can get away with the old bumper reinforcement but you'll need to cut off brackets and elongate the fog light holes
    - washer jets/hose and a newer washer tank with the appropriate higher pressure pump
    - connectors for the headlights and foglights
    - possibly some other bits n pieces that I've forgotten as I suffer from CRS
    With a bit of judicious buying and used bits, your looking at another $500-$1000 plus paint.
    Check the site l322.com too.
    April 15th, 2011
    10
    Thanks FFR.
    Thanks Steve!
    So, I guess I can't just get away with the headlights and the new grille?
    Finding parts like Bumper cover and etc are harder in Canada and quite expensive. So, I think I might have to scrap this Project altogether.
  1. My first Range Rover 2004 HSE
    By Csx7034 in forum Range Rover Mark III / L322
    Last Post: May 25th, 2010, 09:11 PM
  2. considering 2004 range rover
    By tomatojoos in forum Range Rover Mark III / L322
    Last Post: February 21st, 2010, 08:52 AM
  3. 08 model headlights on 04 range rover
    By hdkiwi in forum Range Rover Mark III / L322
    Last Post: November 9th, 2009, 09:30 AM
  4. 2004 range rover
    By presise in forum Range Rover Mark III / L322
    Last Post: June 28th, 2009, 07:00 PM
  5. 05 Range Rover Headlights Auto leveing?
    By wp in forum Range Rover Mark III / L322
    Last Post: September 13th, 2007, 09:22 PM
