Guys I'm Stuck on road Right Now plz help - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 40 of 40
Thread: Guys I'm Stuck on road Right Now plz help
  1. #31
    July 28th, 2018
    Appleton, WI
    53
    Mystery solved. Bad news. The output shaft on tranny and input shaft on transfer case are stripped. I need a new transfer case and tranny. Just really crappy news. Haven't even made the first payment on the Rover yet. Really bummed.
    2012 SC L322
  3. #32
    JUNIOR ROVER MARK_C's Avatar
    January 20th, 2015
    Shrewsbury, MA
    795
    Re: Guys I'm Stuck on road Right Now plz help
    That blows. Maybe this will help with the output shaft, but I don't know what it takes to dig down to the it to get it out, or the new one back in. I'm assuming if you can get a new input shaft for the TC rebuilding that wouldn't be that big of a deal.
    https://cobratransmission.com/ZF6HP2...SABEgJIPfD_BwE
    M Canning
    Massachusetts, USA
  4. #33
    July 28th, 2018
    Appleton, WI
    53
    Thanks Mark
    2012 SC L322
  6. #34
    October 3rd, 2015
    Norco, CA
    85
    Might be cheaper to by a salvaged RR and take the trans and t/c from it and part out the rest. Probably should be exact same year to keep the computers from freaking out though.
    2006 HSE 4.4L Giverny Green
  7. #35
    July 28th, 2018
    Appleton, WI
    53
    Gadzooks yeah I was thinking about the possible computer issues. I also thought about even selling parts that are still good of the stuff I need to replace cuz it might help someone who needs to find a used part but I would have no idea how to get that stuff out on web or whatever where anyone who needs it could buy it. Craigslist doesn't cut it for that. LOL
    2012 SC L322
  8. #36
    February 10th, 2018
    Orlando
    16
    This JUST happened to us 3 weeks ago. Transfer case is "bald" inside and the output shaft is damaged. Used transfer case and transmission installed by local independant shop. Now it will not go into gear. Does anyone know if the newer transmission has to be programmed to work?
    Thanks in advance!
  9. #37
    January 20th, 2015
    Shrewsbury, MA
    795
    What year? Typically yes they do, the Mechatronics unit (the electronics part on the valve body inside the pan) is matched to your VIN. You can use your old one in the new transmission to avoid this kind of problem. I don't know if you can program a new VIN onto one already containing a different VIN.
    M Canning
    Massachusetts, USA
  10. #38
    SENIOR ROVER 03rangiemark's Avatar
    November 28th, 2007
    Orlando, Fl
    1,274
    My 2012 may have had the same problem, but I'm waiting the dealership's prognosis. It does sound like the same symptoms though.
    I was pulling out of one parking lot at work with no problems. Came to a stop where the parking lot goes to a roadway. As I began to pull into the roadway, the engine rev'd freely and I was able to coast to a safe place about 40 feet away.
    After stopping I shut it off, with no dashboard fault indications at this point.
    I then started it up, and when I put it in gear, I just get the ratcheting sound in reverse, and a slightly different ratcheting sound in drive, but no movement.
    When I put it back in park, I can hear it slowly ratchet against the parking pawl until it what ever is ratcheting slowly comes to a stop.
    It sounds like something's broken in there to me, but I'll see what the dealership says.
    The service advisor took a listen to it when I got it to them, and said it sounded familiar to him, like when there's a parking brake failure. Not the case here though, since it rolls freely in neutral (and maybe when in gear too?).
    But they'll be able to look at it in more detail on Monday.
    How can a transmission break like arrukiddenme (and maybe me) experienced?
    In my case, no aggressive acceleration at all, no rough terrain, nothing other than low speed, calm driving in my case, and just driving on the highway in arrukiddenmes case.
    Why would his trans output and transfer case input shaft strip out? Has anyone else heard of this happening?
    Granted, I've only had this for almost 3 months, but it's otherwise in good shape and well taken care of.
    '03 Range Rover HSE
    Black
    '12 Range Rover HSE 'Lux'
    White
  11. #39
    FRESHMAN ROVER dalek1's Avatar
    August 30th, 2017
    Palos Verdes Estates, CA
    38
    Quote Originally Posted by arukiddenme View Post
    Sorry to hear that!
    May I ask where did you purchase the vehicle and did you check the Carfax, service records and get an inspection?
    2011 RR SC
    2014 F-Type S
    2006 RX400h
    2005 XJ8L
    2016 Prius
  12. #40
    November 28th, 2007
    Orlando, Fl
    1,274
    As it turns out, it looks like the same thing is what happened to mine.
    Not real happy with LR if a 2012 can have something so basic fail under normal or even light use.
    Please, anyone that experiences this, report it to the Department of Transportation. It is a safety issue to suddenly lose propulsion in traffic.
    Report it or any other potential safety-related failure to the NHTSA here:
    https://www-odi.nhtsa.dot.gov/VehicleComplaint/
    '03 Range Rover HSE
    Black
    White
  1. My Passenger Door Window is stuck down and it wont go up
    By prodigy215 in forum Range Rover Mark III / L322
    Last Post: August 31st, 2018, 04:13 PM
  2. 1997 Range Rover 4wd Problem?! Help!! plz
    By xxbistrumxx in forum Range Rover Mark II / P38
    Last Post: January 22nd, 2010, 07:50 AM
  3. Stranded In Marble Falls, TX - Plz Help
    By Purple Frogs in forum Range Rover Mark II / P38
    Last Post: July 7th, 2008, 04:12 PM
  4. EAS: It is really my drivebox or my LUCAS EAS? PLZ HELP ME
    By omarawatch in forum Range Rover Mark II / P38
    Last Post: February 11th, 2008, 08:46 AM
  5. Hi..new member from Glos needs help with p38 2.5 dse!!. plz
    By oldpainless in forum Range Rover Mark II / P38
    Last Post: December 18th, 2005, 02:11 PM
