2006 Audio Upgrade - there must be a solution by now? - Page 2
Results 16 to 27 of 27
Thread: 2006 Audio Upgrade - there must be a solution by now?
    FRESHMAN ROVER maximus5403's Avatar
    September 3rd, 2013
    Florida
    17
    Re: 2006 Audio Upgrade - there must be a solution by now?
    Quote Originally Posted by brian2k7 View Post
    Hi Maximus
    You got me thinking now. Where do you plan to move the header to I guess it will be behind the glovebox?
    Can the original head unit be made to switch on auto with ignition, always selected to CD?
    If so then could the replacement header (which in my case is a Dynavin) have its RCA output spliced into the factory CD feed? That way I wouldn't need any extra amps or cabling, and would retain use of the full HK system?
    I removed the CD changer and am installing the factory head unit there. I have to extend wires and optical connections. Then I am installing a Pioneer 8201NEX where the factory head unit sits. In additional I am installing a digital sound processor and 3 small amplifiers for the audio as well as a small sub. The factory amp will stay but all the speakers will be removed.
    Integrating the factory steering controls looks to be a fun project, but worst case is I have seen others tear down the clock spring and run a new wire for steering controls.
    2012 Range Rover Supercharged 5.0
    2007 Range Rover Supercharged 4.2
    January 23rd, 2015
    I did find this on EBay which I may go for.
    http://www.ebay.co.uk/itm/Android-6-...53.m1438.l2649
    May 10th, 2016
    Bolton, UK
    45
    I am now told that I can replace my header with a slightly newer model (still stock LR) and this will give me the option to add an AUX socket.
    (it may just be the difference between LR units YIK500090 and YIK500061 but I can't find any detailed spec on either)
    Can anybody confirm this, and if so how do I find out exactly what revision I have/need, and what AUX socket hardware I will need?
    I have been trying the FM Modulator approach with my iPod but to be honest it's rubbish and I need to keep changing frequencies as I'm driving along.
    March 20th, 2018
    earith
    9
    Hi Brian - did you ever do an upgrade on the 06? I have a few ideas for you if not, the tough bit is connecting to most - have you found a device that takes analog input and converts to the most signal? Also the ipod adapters are quite cheap now
    March 5th, 2018
    Redondo Beach CA
    I gave up after a few audio shops quoted 3-4k to install a new pioneer system and ....
    1. burned a bunch of CDs from my Apple iTunes collection. At least I feel better about all of the money I spent buying those songs.
    2. bought a really good bluetooth speaker that I can turn on and off with my iphone. Use that to stream music. Keep it back in back seat and have it plugged in to keep charged. Not nearly as good as the trucks system but way better than the FM transmitter solution.
    Jgibson308
    2006 L322 HSE
    Black w/ Grey interior
    50K Miles
  8. #21
    March 20th, 2018
    earith
    9
    What year is yours? I have done a conversion to the BMW NBT system in my 2003 l322. It needs access to the ibus and BMW can system. I believe the earlier 2006s still had this - ibus for the clock and can for some of the other systems. The nbt then has a most output for the amp. I have not tried this yet but can’t see a problem with it
  9. #22
    September 10th, 2014
    Australia
    30
    Doing mine at the moment, just having issues with the steering controls, will post a pic when finished!
  10. #23
    March 20th, 2018
    earith
    9
    Did yours have the touchscreen? How are you getting the Audio output to the most system?
  11. #24
    Australia
    30
    Yep it is touchscreen, very responsive & the audio is great, the instructions though - terrible, having to go through it myself! As before the only issue is the steering controls as there is only one wire from the unit for the keys and on my last one that i fitted there were two and the steering functions worked fine.
  12. #25
    Australia
    30
    All done, except I couldn't work out the steering controls, save that for another day!
  13. #26
    March 20th, 2018
    earith
    9
    No I meant did it have the touchscreen originally? With the harman sound system?
  14. #27
    Australia
    30
    Ohh, no it was the basic unit.
  1. Bluetooth Audio SOLUTION!
    By redranger in forum Range Rover Mark III / L322
    Last Post: June 27th, 2018, 04:36 AM
  2. Audio upgrade shop in London
    By lazydog87 in forum Range Rover Sport II / L494
    Last Post: November 30th, 2016, 07:09 AM
  3. 2008 HSE - Bluetooth Audio Issues - iPhone 6 - Solution
    By mjmurray68 in forum Range Rover Mark III / L322
    Last Post: December 4th, 2014, 12:56 PM
  4. 2006 transmission solution
    By rturbett in forum Range Rover Mark III / L322
    Last Post: July 22nd, 2013, 04:32 AM
  5. Audio Screen - Problem and Solution.
    By Mr R in forum Range Rover Mark III / L322
    Last Post: October 17th, 2012, 04:44 PM
