Rough gear change from 2 to 3 and 3 to 2. 4.2 SC
Results 1 to 4 of 4
Thread: Rough gear change from 2 to 3 and 3 to 2. 4.2 SC
    October 20th, 2016
    Wiltshire
    Hi, really hope someone can help me I'm suffering with really rough clunky gear change from 2 to 3 and back down. It got a lot worse the other day when I used the HDC, it gets much worse when the gearbox has warmed up.
    Any help would be much appreciated, I'm away on holiday in the lake district over Christmas and it can't be doing the car much good.
    JUNIOR ROVER Flash G's Avatar
    February 8th, 2007
    Hollywood Hills
    699
    Re: Rough gear change from 2 to 3 and 3 to 2. 4.2 SC
    Are you sure it's not 1-2 and 2-1? That's a very common problem on 06-09 cars.
    `07 Lotus Exige S - Ardent Red
    `06 Range Rover Supercharged - Java Black
    `06 Range Rover Sport HSE - Java Black
    `05 Lotus Elise - Ardent Red
    `97 Range Rover 4.6 HSE (Sold)
    August 15th, 2006
    Blackburn, UK
    2,264
    Assuming that it is the 2-3 & 3-2 shifts which are problematic, and bearing in mind that the majority of issues with the 6HP26 are caused by failing solenoids, I would be tempted to try swapping out the EDS 2 (B clutch) & EDS3 (C brake) solenoids (the B clutch & C brake are being exchanged during the 2-3/3-2 shift).
    Note that the yellow cap solenoids (EDS 1, 3 & 6) have a rising pressure characteristic with current and for the blue cap solenoids (EDS 2, 4 & 5) the pressure reduces with increasing current.
    Phil
    November 29th, 2017
    Los Angeles, CA
    14
    Quote Originally Posted by Flash G View Post
    Old thread I know, but could you elaborate on this? I did a search but didn't see much of a pattern (though it did get me here).
  1. Slow to change gear
    By alistair in forum Range Rover Mark III / L322
    Last Post: February 25th, 2014, 03:26 PM
  2. Gear change issues
    By briang in forum Range Rover Mark II / P38
    Last Post: April 16th, 2013, 05:42 AM
  3. Delayed gear change
    By neo3670 in forum Range Rover Mark II / P38
    Last Post: April 22nd, 2008, 02:53 PM
