No Sports Mode or Manual Mode 2006 RR
Results 1 to 2 of 2
Thread: No Sports Mode or Manual Mode 2006 RR
    September 14th, 2016
    Houston Texas
    So i can shift lever to the left but the sports mode does not come up on the dash.
    It runs fine and not issues with transmission.
    If I try to shift gears manually it says transmission fault and also no indication on dash that it is in manual mode.
    Could something be disconnected or is the transmission actually bad?
    August 12th, 2016
    Los Angeles CA
    103
    Re: No Sports Mode or Manual Mode 2006 RR
    I would start by pulling off the leather cover over the gear shifter and when you switch over the lever there is a litttle micro switch below that is supposed to click when the lever is switched over check for damage to the micro switch for for and water damage from a cup of coffee or anything else that could have gotten in there
  1. L322 unwanted sports mode
    By dscowley in forum Range Rover Mark III / L322
    Last Post: March 25th, 2014, 07:00 AM
  2. Problem with 'Sport' mode and 'Manual' mode
    By roverfan1975 in forum Range Rover Mark III / L322
    Last Post: November 25th, 2013, 10:25 AM
  3. Automatic mode noise but not on Manual mode
    By blkblkrover in forum Range Rover Mark III / L322
    Last Post: July 2nd, 2010, 08:03 AM
  4. Stuck in Sports mode
    By lannyleeds in forum Range Rover Mark II / P38
    Last Post: June 14th, 2007, 02:00 PM
  5. sports mode???
    By redrange in forum Range Rover Mark II / P38
    Last Post: March 2nd, 2007, 07:02 AM
