What adhesive should I use to fix clip bracket back
Results 1 to 3 of 3
Thread: What adhesive should I use to fix clip bracket back
    March 1st, 2013
    Urbana, IL
    106
    Hello all,
    I removed my driver's door (LH) panel recently and found several clip brackets falling off the door panel. Maybe I pried at the wrong point, but anyway... I can't tell what adhesive was used to glue the brackets to the back side of the door panel, but I think I'm supposed to glue them back...
    Any suggestions what adhesive I should use? Glue, or maybe tape? And how should I remove the residuals of the old glue?
    I've looked at several adhesives...
    3M panel bonding adhesive (08115 or similar), good for steel, aluminium, SMC and FRP (I don't really know what material is the door panel back plate made of), but is difficult to apply, needs tools, etc.
    3M semi-rigid plastic repair (34240 or similar), used for bonding materials such as plastic, etc.
    3M automotive acrylic plus premium attachment tape (06387 or similar), used for installing heavy trim parts such as side moldings, etc.
    And there are many many more Loctite products...
    Suggestions will be greatly appreciated!
    ↑↑↑ Brackets and clips on them that didn't come off with the panel but stayed with the hole;
    ↑↑↑ Door panel back plate with missing brackets and adhesive residuals (some opaque, yellow-ish, rigid residuals).
    2003 Land Rover Range Rover HSE 4.4L V8 (ext. Java Black; int. Sand/Jet Black + Burled Walnut)
    ______________________________________________
    June 14th, 2014
    Upstate NY
    694
    Re: What adhesive should I use to fix clip bracket back
    I wouldn't worry about it. There are a ton of other clips, and chances are they'd come right off again anyway.
    May 2nd, 2015
    MS/NC
    145
    I would put the clips back unless you want the door panel to rattle. That is a sign of crappy craftsman ship to just leave them off. The engineers put there there for a reason. The 3m 34240 should work well. permatex plastic weld would hold great also.
    2008 Range Rover Supercharged L322.
    2010 Range Rover Autobiography L322.
  1. Rear Bumper Support Bracket Clip & Suspension Air Reservoir Queries
    By Clive603 in forum Range Rover Mark II / P38
    Last Post: July 7th, 2014, 03:26 PM
  2. Picked up a Vitesse a few months back - looking to fix it up
    By the_auto_tec in forum Range Rover Mark II / P38
    Last Post: September 15th, 2012, 08:51 AM
  3. Engine shaking -do I fix or dump car back on dealer
    By bisktnbskt in forum Range Rover Mark III / L322
    Last Post: February 23rd, 2012, 03:23 PM
  4. Driver Seat Back Reclines By Itself..It There A Fix?
    By LR4Life in forum Range Rover Mark II / P38
    Last Post: March 2nd, 2010, 05:52 PM
  5. '89 Range Rover, distributor cap won't clip back on!!
    By rrc in forum Range Rover Classic
    Last Post: April 26th, 2009, 11:37 AM
