06-09 trailer wiring installation
Results 1 to 4 of 4
Thread: 06-09 trailer wiring installation
    FRESHMAN ROVER RoverP38's Avatar
    January 18th, 2012
    Bucks County, PA
    116
    So I finally found a used trailer wiring kit for my 2008 Range Rover full size and have a few questions. The only instructions I can seem to find online are for the 2003-2005 wiring. Has anyone installed one for the 06-09 models?
    - The 03-05 instructions show a loose red wire from the wiring harness that you need to plug into the white connector above the relays. I dont see this red wire at all in my harness.
    - The 03-05 instructions have a 30 amp fuse and relay that you must install. None of this came with the (used) kit I bought and not really sure if it was apart or needed for 06-09 models?
    - Lastly, the wiring harness I have comes with 3 harnesses branching off - 1 connector goes to the module, 1 connector goes to the white connector right next to the module mount, and then there is a third that just looks like a relay of some sort? The 03-05 only shows the first 2 connectors I listed above.
    - Does the 06-09 model need to be programmed for the trailer harness to work?
    Sorry for the numerous questions but I just want to be sure that everything is installed correctly before I hook it up.
    June 14th, 2014
    Upstate NY
    694
    Re: 06-09 trailer wiring installation
    I just did mine and still have the instructions. If you cant find them in a day or so, I will post
    October 31st, 2012
    Chicago
    48
    Hello,
    > I own a 2006 Range Rover HSE 4.4L Jag Engine version and purchased the
    > trailer wiring kit YWJ500012. There is a slight difference when installing
    > it and was wondering if you could help me out?
    > I'm having the same issue with were one of the connectors on the harness is
    > suppose to connected to, and if I need to add a 30amp fuse. I have attached
    > some pictures. First pic (20150512_11320 is of the 3 connectors. The one
    > in the middle (looks to have a fuse-able link/resistor plugged into it),
    > were is this suppose to be attached to? Second pic (20150512_113230) is a
    > close up of the middle connector. Third pic (20150512_114209) is of my rear
    > electrical panel of my 2006 Range HSE. If you look at the panel to the top
    > right that has nothing plugged into it (right above a black fuse/resistor
    > with horizontal yellow line). is this were the fuse/resistor attached to
    > the middle connector on the wire harness is to be pulled off the connector
    > and attached there? fourth pic (20150512_114241), another angle with the
    > opened spot on rear electrical panel.
    > Also, will there need to be any programming done after installation?
    > Thank you
    Attached Thumbnails Attached Thumbnails 06-09 trailer wiring installation-20150512_113208.jpg   06-09 trailer wiring installation-20150512_113230.jpg   06-09 trailer wiring installation-20150512_114209.jpg   06-09 trailer wiring installation-20150512_114241.jpg
    NEWBIE jacklambert's Avatar
    February 6th, 2017
    Reston, VA
    I also have a 2008 with the same challenge. Can anyone assist? Where the single orange wire goes and the relays is the challenge.
  1. 2011 Range Rover Sport Trailer wiring harness (VPLST0016) installation
    By johnmoeinfl in forum Range Rover Sport / L320
    Last Post: April 12th, 2015, 05:03 PM
  2. Trailer kit installation - she no worky
    By Gorf in forum Range Rover Mark III / L322
    Last Post: February 20th, 2012, 11:49 AM
  3. Trailer Wiring
    By piprover in forum Range Rover Mark II / P38
    Last Post: August 5th, 2011, 12:00 PM
  4. Trailer Hitch Installation and Price
    By At Law in forum Range Rover Sport / L320
    Last Post: May 1st, 2009, 12:22 PM
  5. Trailer Wiring Help PLEASE!!!!!
    By Jnphil in forum Range Rover Mark II / P38
    Last Post: June 22nd, 2006, 01:30 PM
