P0089-64 (E8) Fuel Pressure Regulator 1 Performance
Results 1 to 3 of 3
Thread: P0089-64 (E8) Fuel Pressure Regulator 1 Performance
    October 30th, 2018
    20
    2016 Range Rover Sport Supercharged 86K miles. (Out of Warranty) is showing the following Code: PCM-Engine Petrol V6
    P0089-64 (E Fuel Pressure Regulator 1 Performance -Algorithm based failure-signal plausibilty failure.
    What is the real cause of this code?
    Is it the Fuel Pump?
    OR the Low Pressure and/or High Presure sensor(s)?
    Software Update?
    How to update the software using GAP Diagnostic?
    October 30th, 2018
    20
    Re: P0089-64 (E8) Fuel Pressure Regulator 1 Performance
    The Check Engine Light disappeared for a day and a half and returned today. I overfilled the tank and it went away. When I hit 75%, the Check Engine Light reappears.
    September 29th, 2018
    long island, ny
    213
    Quote Originally Posted by EdwardRR View Post
    Software Update?
    P0089-64 Fuel Pressure Regulator 1 Performance - Signal plausibility failure NOTES:
    • Monitor description. The command signal to the fuel pump driver module is above a threshold
    • This DTC is set when the powertrain control module has detected plausibility failures.
    • Fuel system leakage from the fuel tank and lines
    • Low pressure fuel pump failure
    • Check for fuel system leakage from the fuel tank and lines both internal and external of the fuel tank
    • Using the Jaguar Land Rover approved diagnostic equipment, clear the DTCs and retest
    • Check and install a new low pressure fuel pump as required
    2019 Range Rover Sport HSE Dynamic
  1. 2016 Range Rover Sport (L494) Code: P0089-64 (EC)
    By EdwardRR in forum Range Rover Sport II / L494
    Last Post: April 10th, 2019, 03:56 PM
  2. P0089-64 Code
    By Jmpacker in forum Range Rover Sport II / L494
    Last Post: December 31st, 2018, 02:00 PM
  3. P0128-00 (E8) Engine Light
    By Wacko in forum Range Rover Sport / L320
    Last Post: March 27th, 2018, 03:14 PM
  4. Fuel pressure regulator P0089
    By Rovingvic in forum Range Rover Evoque / L538
    Last Post: May 14th, 2014, 09:20 AM
  5. Fuel pressure regulator
    By Rover Dan in forum Range Rover Classic
    Last Post: January 26th, 2006, 03:20 PM
