Brake Pad Worn - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 32 of 32
Thread: Brake Pad Worn
  1. #31
    February 26th, 2019
    33
    Re: Brake Pad Worn
    Quote Originally Posted by gsolo9559 View Post
    Hello All,
    A lot of good information here about the brakes and rotors.. If I were to use someone different than the LR Dealer, does it void my warranty? I thought to keep the warranty you must use the dealer, I may be wrong and will review my contract... Thanks
    I believe it’s illegal for dealerships to void warranty unless there is a modification done.
    On the the recommendation of this forum, I ordered the Disc Italia brake pads and am using oem rotors. Total cost is gonna be around 1750 at an independent, including pads, rotors and sensors. The hourly rate at this shop is pretty high at 120/hr, but they are the best/only real game in town for all the high end vehicles around. Oil change was $140, whereas the dealership wanted 595 and “threw in” a bunch of other things... They service my 911 turbo too, so I trust their quality.
  3. #32
    December 15th, 2017
    Cincinnati OH
    51
    Re: Brake Pad Worn
    Hello All,
    In addition to what FASTCARFREAK stated: Your warranty can not be voided unless you do some sort of modification or you fail to meet the terms of the warranty. Then they can only void the warranty for that item /system. So doing a resonator delete could void your warranty on the engine, it will not void the warranty on your seats for example.
    2018 RRS V-8 SC Dynamic
    2017 RRS TD6 (buyback)
  1. Brake Pad Replacement - Now Spongy Brake Pedal
    By lesjonpool in forum Range Rover Mark II / P38
    Last Post: November 3rd, 2013, 05:37 PM
  2. Brake Problem / Brembo Brake Pad pins stuck
    By armydiver in forum Range Rover Mark III / L322
    Last Post: April 27th, 2013, 11:57 AM
  3. How do I reset the "Check Brake Pad and Brake" light warning
    By scharlesjr in forum Range Rover Mark III / L322
    Last Post: March 3rd, 2010, 02:23 AM
  4. Brake Pad light on and options to get a brake Job done
    By ayates in forum Range Rover Sport / L320
    Last Post: April 24th, 2009, 06:23 AM
