2014 RRS Autobiography headlights not working
Results 1 to 11 of 11
Thread: 2014 RRS Autobiography headlights not working
    FRESHMAN ROVER FitnessTori's Avatar
    March 15th, 2019
    My regular headlights and high beams stopped working. First the left then a couple days later, the right. Took to the dealer and they said the entire headlamps need to be replaced on both sides at a whopping $6600!! I can’t help but think there has to be a short or something else going on to cause this. I’m sure it’s POSSIBLE they both failed within a week of each other, but doesn’t seem likely. Of course my extended warranty won’t cover it. Any ideas???
    December 21st, 2018
    Boston, MA
    86
    Re: 2014 RRS Autobiography headlights not working
    Quote Originally Posted by FitnessTori View Post
    What did the dealer say the issue is with the headlights? I'd be shocked if both units failed completely at 5 years old. That seems crazy. Are the housings compromised in some way (i.e. did they get cracked and water get in there) or is it an electrical issue? The price doesn't shock me for complete headlight units with associated modules and labor to install. I had a 2012 Audi A6 Prestige with LED headlights and the driver's side headlight got cracked by road debris - the replacement cost was well over $3k all-in, as the whole unit needed to be replaced, and the unit itself was $2700. I just question whether your headlights have failed or there's something else going on. If it's not covered by extended warranty then take it to an independent mechanic for an assessment.
    2019 RRS SCV8 ATB L494, Indus Silver (on order)
    2017 Range Rover SCV8 L405, Scotia Gray (wife's car)
    SENIOR ROVER 383vett's Avatar
    October 31st, 2013
    Moraga, California
    1,332
    Here you go, even less if not bi zenon.
    https://www.ebay.com/itm/2014-2015-2...4AAOSwSjpcd06v
    https://www.ebay.com/itm/2014-2017-R...4AAOSw6KxcN8Vp
    You should be able to swap these out with little effort. Ebay has a ton more.
    March 15th, 2019
    No crack at all. I am going to take it somewhere else for another opinion. Apparently you have to remove the bumper when changing out the headlamps which makes it more of a project then I want to do. I’m really of the opinion that something else is causing this though.
    September 28th, 2017
    Ny
    29
    my left headlight recently went out. no error lights or anything. i replaced the ballast on the bottom of the headlight. problem fixed. ballast cost anywhere from $22-$125 dollars. if you are handy, it takes less than an hour to remove each headlight and fix. you dont need to fully remove the bumper.
    September 5th, 2017
    Gosford, NSW, Australia
    10
    I would start with the bulbs.... The replacement bulb is a D3S, 35W . From the workshop manual:
    Headlamp removal is not required for the replacement of the xenon bulbs. The rear of the headlamp unit has a removable access cover which allow access to the bulb.
    A large cover, which is rotated counter-clockwise to remove, allows access to the low/high beam xenon bulb.
    .... the D3S bulb incorporates an integral igniter unit and both components must be replaced if the bulb fails.
    .... Handling of the D3S xenon bulb must be performed using suitable protective equipment, e.g. gloves and goggles. The glass part of the bulb must not be touched.
    Ny
    29
    Quote Originally Posted by GregRRS View Post
    if the bulbs go out, you would get a dash light, and you do not need to replace the bulb and igniter/ballast together.
    March 15th, 2019
    No dash notifications came on. I will try ballast once I get it back. I also read that if you have a transponder close the the rear view mirror, headlights may act up. Not sure how or why, but I’m also going to take that off for giggles and see if it makes a difference.
    March 15th, 2019
    So far taking the transponder of the window by the rear view mirror has caused my headlights to flicker on for a secon or two. More than the ZERO I was getting before. It’s so strange! I ordered the ballasts, bulbs and wiring and will take it in to a local mechanic and see if one of those is the answer. Still trying to avoid the cost of the entire headlamp units.
    March 15th, 2019
    Replaced the bulbs before doing anything else. Works!! BEWARE: NEVER use LandRover Anaheim Hills CA for service unless you have money to throw away
    March 15th, 2019
    Ended up just being bulbs. Thanks local car mechanic for saving me $7000!!!
  1. 2014 RRS L494 change the headlights to 2018
    By abo wajd in forum Range Rover Sport II / L494
    Last Post: October 16th, 2018, 03:54 PM
  2. Headlights flash Central Locking and Electric Windows not working
    By Farmer Fred in forum Range Rover Mark II / P38
    Last Post: June 10th, 2013, 12:47 AM
  3. Key fob not working, EKA not working...Actuator problem?
    By firestarter_phil in forum Range Rover Mark II / P38
    Last Post: February 22nd, 2009, 07:20 AM
  4. Steering Wheel not working, TILT + TELESCOPE not working
    By charly_talon in forum Range Rover Mark III / L322
    Last Post: September 19th, 2008, 03:50 AM
