Uh oh - rear differential leak?
Results 1 to 15 of 19
Thread: Uh oh - rear differential leak?
    February 11th, 2010
    287
    Noticed some oil in the parking spot at the rear of the car. When I looked, I found an oily rear diff. I just had the car serviced... Does the rear diff fluid get changed/checked? https://photos.smugmug.com/photos/i-...2BB4M8W-XL.jpg
    JACK'S GRANDAD leftlanetruckin's Avatar
    August 26th, 2007
    9,077
    Re: Uh oh - rear differential leak?
    In theory, all fluids should be checked whenever it's in there. In reality.......
    '11 L322 SC
    '04 DiscoII - wheeling rig
    Moderator RRToadHall's Avatar
    27,569
    It's way too early for any 494 owner to need diff fluid change. I would doubt that they bother to check it this early. Most likely it as simple as a seal damaged during assembly.
    ~ Maharishi Mahesh Yogi~
    LIFETIME CONTRIBUTOR Brimill1234's Avatar
    January 14th, 2013
    Holmdel, NJ
    1,379
    They may have checked it and topped it off and left it oily from some spillage. If you want to save a trip in clean it off and check again in a few days to see if it's still getting coated.
    2013 RRS HSE LUX Santorini black
    QuickSilver Exhaust
    20" Redbourne Nottinghams
    I am a professional so please use caution, I may have enjoyed a few cocktails when I told you to go ahead and try this at home...
    SENIOR ROVER Jaguar27's Avatar
    December 9th, 2012
    SoCal
    1,170
    Quote Originally Posted by leftlanetruckin View Post
    Or at least check for leaks, right Martin?
    ‘18 Range Rover - Corris Grey/Black
    ’ 19 Jaguar F-Type Coupe - Fuji White / Red
    '16 Jaguar F-Type Roadster - Fuji White/Black
    ‘16 Range Rover Sport HST - Fuji Whie/Black (sold)
    2014.5 Range Rover Sport HSE - Fuji White / Almond & Espresso (sold)
    2013 GT Limited Edition - Fuji White/Black (sold)
    Carpe Diem !
    August 26th, 2007
    9,077
    For that money? Yep
    '11 L322 SC
    December 2nd, 2014
    Indianapolis, Indiana
    Yep, been there. Saw oil spot, took it in, and was told rear pinion seal was bad, which required they rebuild it during Visit #1. Scheduled Visit #2 for the following week, showed up, and was told they had another one up on the lift and found out they needed a special tool that they didn't have. Went home and received a follow up call a week later that the tool was in, and so scheduled Visit #3. Dropped of the car and was told they probably needed it overnight. When i hadn't heard anything at the end of day 2, called, and was told there was yet another special tool they didn't have, but that Land Rover was lending them via overnight package. Ended up getting the my RRS back 2 days later. Love the vehicle, not the service.
    December 31st, 2013
    AB, Canada
    25
    I had the same issue. Had an oil spot on my garage floor (now permanently stain). Took it in and it was a seal leak. Replaced same day.
    Sent from AutoGuide.com Free App
    April 15th, 2014
    Boston, MA
    40
    Also have rear diff leak. Spotted by local LR tech (independent shop) doing oil change #2. Called 3 local dealers, earliest I can get it in in Jan 18. Don't know if that reflects well on # of vehicles needing service?!?
    February 11th, 2010
    287
    Diagnosis was front pinion seal leak at the rear differential. Repair was covered under warranty.
    In addition to the reports above, there are a few additional ones on the UK RRSport site as well. Seems like this might be a common issue.
    February 11th, 2010
    287
    Front pinion seal at rear differential was leaking. Replacing the seal did not fix the leak.
    Replacing seal and bearing fixed the leak, but now differential is making a weird sound.
    LRNA is replacing the diff under warranty. 8 days and counting without my car.
    December 2nd, 2014
    Makes sense. I was told that the fix required a rebuild and that if after the rebuild, if I noticed increased noise, LR already committed to putting a new diff in.
    August 26th, 2007
    9,077
    Wow.
    Sounds like they knew it was an issue already, not cool.
    Hope the loaner is as good as the Rover though.
    '11 L322 SC
    FORUM MODERATOR sblvro's Avatar
    March 12th, 2012
    Little Rock, Arkansas
    1,963
    It's a common issue in any vehicle with 4wd. Leaks that can be just a seal leak not overhaul. I had a seal leak in my 2009 escalade hybrid at 195k miles
    http://forums.evolutionm.net/members/596-sblvro.html
    https://www.facebook.com/pages/doctorownedcarscom/217367714961131
    011 RRS hse lux (traded),2013 RRS hse lux +silver, vision package(current),2009 escalade hybrid(traded) for 2015i escalade platinum,2014 glk 350 4matic(current)
    August 26th, 2007
    9,077
    All we have is 4wd rigs, and have yet to have one leak as new as the OP's did.....
    Close to 200k miles is a LOT different than this guys situation.
    Not to mention that the rear axle has absolutely no idea whether it is 2wd or 4wd. It acts the same either way......
    '11 L322 SC
  1. 2006 RRS HSE rear differential leak
    By ultraslan in forum Range Rover Sport / L320
    Last Post: October 19th, 2014, 04:28 AM
  2. Rear differential
    By gooseyloosey in forum Range Rover Sport / L320
    Last Post: April 4th, 2012, 08:58 AM
  3. Rear Differential ???
    By lisa in forum Range Rover Mark III / L322
    Last Post: March 3rd, 2008, 05:19 PM
  4. Differential oil leak-need help
    By icarumba in forum Range Rover Mark II / P38
    Last Post: May 20th, 2006, 05:11 PM
