Hdc fault system unavailable, gear fault
Results 1 to 14 of 14
Thread: Hdc fault system unavailable, gear fault
    December 18th, 2015
    PORT HARCOURT, NIGERIA
    Got home from work this evening. Chilled out at home for awhile, wanted to take a ride into town to pick up a few groceries.....cranked the engine on...saw HDC fault and wont shift into gear. Any ideas what the issue is? My lady is a 2014 range rover sport.
    11,013
    Re: Hdc fault system unavailable, gear fault
    Could be a low battery. Did the engine start? How?
    November 15th, 2015
    Chicago, IL
    58
    Try disconnect the battery and then reconnect.. Could clear out what's going on.
    cgs
    cgs is offline
    January 20th, 2015
    Chicago, IL, US
    274
    You almost certainly need to get the TCM update flashed (Q453). If it won't go into gear after waiting, you'll probably need a tow. The transmission release is under the cup holder floor. Just pry it up via the almost imperceptible slot with a screwdriver and hold the strap while it's put onto the flatbed.
    Also, see https://www.rangerovers.net/forum/43-...x-failure.html.
    December 18th, 2015
    The engine starts just fine, gives error message that the rear view camera inoperative, and would not engage any of the gears. Where can I find the battery? might try a hard reset but don't know the location of the battery. thanks for your ideas!!
    27,612
    Quote Originally Posted by EJIRO View Post
    As you have two batteries and entirely different systems from earlier models I certainly would not be doing hard resets on the new gen rigs. There is an existing "where can I find the battery" thread just a few down from this.
    December 18th, 2015
    Finally found the location of the battery underneath the spare tyre. Disconnected the negative terminal for 2hrs, but situation remained unchanged after reconnection. Just got a technician in from LR to check it. So happy it happened at home!! Will keep you guys posted on how it worked out.
    December 18th, 2015
    Still haven't resolved the Hdc fault system unavailable, gear fault issues. Got a dealer to take a look at it. Threw out Fault codes 1.U0402-Invalid data received from transmission control module 2. U0103- LOST COMMUNICATION WITH GEARSHIFT MODULE and 3. P0850- Park/Neutral switch input circuit. I seriously need help in resolving all these issues. Would be glad if I can get some steers in the right direction.
    May 14th, 2015
    UK
    11
    I had this exact issue, however it resolved its-self after locking the car, leaving for 5 mins and unlocking.
    However, I would assume that you've tried this?
    December 18th, 2015
    Yes I've done this. Infact it became normal on its own a couple of days ago, but when I switched off and switched back on the fault returned. I'm really getting frustrated with the rig. I really would need suggestions on how to overcome this issue.
    December 29th, 2013
    Windham, New Hampshire
    1,681
    your rig is under warranty. it has an electric issue, maybe a faulty sensor somewhere which might need to be replaced. the only reasonable suggestion is "take it to professionals". looking at your location, I'm not sure if it's a simple thing to do.
    May 14th, 2015
    UK
    11
    Check the battery output, its the first thing which the LRA technician did with mine, it might be that you require a new battery.
    December 18th, 2015
    Update on the Hdc fault system unavailable and gear fault I had been experiencing. Got the technicians to look at it at home (since I didn't want it towed) for about 2 weeks. They couldn't figure out exactly what was wrong. Anyway I was asked to replace the TRANSFER SHIFT CONTROL. Unbelievably, the car has been engaging into gears perfectly for the past 2 days. Nothing was changedI really dont know if it will re-occur. These vehicles are strange!! I normally can check the battery voltage of my ML350 from the dash. Anyone know how is done on the 2014 Range Rover Sport?
    June 4th, 2014
    Arlington, VA
    1,089
    Get a simple voltmeter and go to the battary jumper terminal in the engine bay measure between the + red terminal and any unpainted metal part in the engine bay. Battery is in the trunk but its more accessible in the hood to do this. I have this cheap DMI iotech smart digital multimeter. Its cheap and very versatile. I bought it for wiring my dash-cam into my ATB.
    2019 Mercedes Benz AMG-E63S
    2015.5 RRS Autobiography, deployable side steps
  1. Hdc fault system unavailable
    By GuNBeeM in forum Range Rover Sport / L320
    Last Post: May 3rd, 2019, 12:49 PM
  2. Replies: 18
    Last Post: February 20th, 2019, 11:14 AM
  3. HDC Fault, System unavailable - Suspension lowering
    By daboysnyc24 in forum Range Rover Mark III / L322
    Last Post: August 9th, 2015, 12:07 AM
  4. Transmission Fault Traction Reduced, HDC Unavailable, Etc
    By killerwords in forum Range Rover Mark III / L322
    Last Post: July 2nd, 2015, 07:05 AM
