'17 HSE TD6 - Want to add Active Locking Differential
Results 1 to 2 of 2
Thread: '17 HSE TD6 - Want to add Active Locking Differential
    June 19th, 2017
    Dallas, TX
    I've identified several of the parts needed to add the active locking differential, which based on LR4 owners' experience can be done with addition of the correct wiring harness. I don't believe the ECU even had to be notified that the differential controller was there as it registered itself on the CAN-BUS. My question is, does anyone know the wiring harness part numbers i can add to my list?:
    1) Differential Unit - https://www.jlroriginalparts.com/oem...embly-lr041961
    2) Left Axle Assembly (right appears to be the same as non-locking) - https://www.jlroriginalparts.com/oem...embly-lr073345
    3) Active Locking Differential Control Unit - https://www.roverjaguarparts.com/oem...odule-lr086488
    4) Actuator Housing - https://www.jlroriginalparts.com/oem...using-lr043121
    5) Actuator - https://www.jlroriginalparts.com/oem-parts/land-rover-actuator-lr041966
    |2017 RR HSE TD6|
    February 6th, 2016
    Norton,VA
    16
    Re: '17 HSE TD6 - Want to add Active Locking Differential
    I am very interested in this build. I have a 16' TD6 that is my daily driver and it has 65K miles. Planning to keep it for the long haul and would eventually like to have a rear locker....
