Alternate Replacement Head Units for older L405's - Page 8
Page 8 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 106 to 120 of 127
Thread: Alternate Replacement Head Units for older L405's
  1. #106
    SOPHOMORE ROVER W84IT's Avatar
    June 29th, 2010
    Indio, CA
    417
    Re: Alternate Replacement Head Units for older L405's
    update:
    I decided to give my local LR dealer another shot at finding the problem so I dropped off my L405 to them yesterday morning. The service manager told me that he would speak with LR in regards to a good will repair but he couldn't guarantee anything. As of this morning, I still haven't received a call with any news so I assume they didn't even get a chance to look at it yesterday. On the flip side to that, Andy, the seller from Canavie sent me a replacement Android screen try the install again after the problem has been resolved. I shipped the other unit back to him for testing. Anyway, I will update again once I hear something from the LR dealer.
    Ray
    Current:
    2013 Range Rover L405 HSE(Fuji White with Almond Interior)
    Previous:
    2010 Range Rover L322 HSE(Alaska White with Jet Interior)
    2005 Range Rover L322 HSE LUX(Zambezi Silver with Charcoal Interior)
    2005 Range Rover L322 HSE(Zambezi Silver with Charcoal Interior)
    2004 Range Rover L322 HSE(Adriatic Blue with Sand Interior)
  3. #107
    FRESHMAN ROVER BigladUK's Avatar
    January 28th, 2019
    UK
    44
    CarPlay wireless adapter just arrived
    Alternate Replacement Head Units for older L405's-a2c97fdd-4443-4d77-a1e7-77aa08d3954a_1559752236746.jpgAlternate Replacement Head Units for older L405's-b6d4523c-5219-46e7-a1c8-0cf012433c3f_1559752246178.jpgAlternate Replacement Head Units for older L405's-810c6b71-404f-4d39-a45e-5679e6eaf98d_1559752226690.jpgAlternate Replacement Head Units for older L405's-e0db93a6-08a7-45bd-90ea-d20d6146d661_1559752213773.jpg
  4. #108
    June 29th, 2010
    Indio, CA
    417
    update:
    I called the service manager at the LR dealer today and he informed me that they found the problem. The shop foreman was able to get the ECU's back working so everything is in working order now except the screen. The screen does not even turn on. I guess that means the boards that I swapped over during the install caused a glitch to the system. The bad news is that a brand new factory coded screen will cost $2700. I asked the service manager if I could use a donor screen but he said that he wasn't sure if that's even possible because the screens are coded to the VIN from the factory. Therefore, it would have to be a brand new factory coded screen. I asked him to please verify that with the shop foreman because I definitely don't want to have to pay $2700 for a brand new screen. He said that he would give me a break on the diagnostic charge but I'm still probably looking at about $400+ just for diagnostic. I've already found a donor screen so I hope that it can be coded to work in my L405. Anyway, I'll report back when I have more info.
    Ray
    Current:
    Previous:
  6. #109
    June 29th, 2010
    Indio, CA
    417
    update:
    Well, I picked up my L405 from the dealer today but apparently the service manager had given me the wrong information in regards to everything working again except the screen not turning on. I actually got to speak with the shop foreman and he said that they ECU's are not responding due to the screen not working. He said that the screen is the gateway for the MOST Network and I would need to replace the screen in order for him to diagnose further but the bad screen is more than likely the source that's causing everything else not to work. I guess that makes sense...I'm assuming that when I swapped the 2 circuit boards over from the original screen to the android screen something must have happened during the install that killed the circuit boards. The MOST network plugs into one of those circuit boards. Anyway, I'm now in search of a donor screen that I can get a set of circuit boards from to swap over to the android unit.
    Ray
    Current:
    Previous:
  7. #110
    June 29th, 2010
    Indio, CA
    417
    OK guys, I was able to source a brand new donor screen from eBay for $400! That's much cheaper than the $2700 that the LR dealer quoted. I did find a few other donor screens that were even cheaper but the part numbers didn't match my original screen so I didn't want to take a chance because I wasn't sure if the circuit boards would be the same. The 2 circuit boards that have to be swapped over to the new android screen are the key to everything working again. I will update you guys again once it get the new screen unit.
    Ray
    Current:
    Previous:
  8. #111
    June 29th, 2010
    Indio, CA
    417
    UPDATE!!!
    OK guys, I first want to thank forum members BigladUK and mark1107 for their help in trying to figure out the problem. BigladUK actually found me a cheap donor screen in the UK and I paid a total of only $133.02 with shipping included so I passed on the donor screen that I found on Ebay for $400. The screen from the UK arrived yesterday evening and I transferred the 2 circuit boards over to my new android screen...now my original menu screen is back in order and everything is working again!
    Attached Thumbnails Attached Thumbnails Alternate Replacement Head Units for older L405's-img_6984.jpg
    Ray
    Current:
    Previous:
  9. #112
    June 29th, 2010
    Indio, CA
    417
    This is the board that failed from my original screen...
    Attached Thumbnails Attached Thumbnails Alternate Replacement Head Units for older L405's-img_6965.jpg   Alternate Replacement Head Units for older L405's-img_6966.jpg
    Ray
    Current:
    Previous:
  10. #113
    June 29th, 2010
    Indio, CA
    417
    factory screen vs new android screen...
    Attached Thumbnails Attached Thumbnails Alternate Replacement Head Units for older L405's-img_6651.jpg   Alternate Replacement Head Units for older L405's-img_6984.jpg
    Ray
    Current:
    Previous:
  11. #114
    June 10th, 2019
    4
    Quote Originally Posted by BigladUK View Post
    How does it work?
  12. #115
    June 29th, 2010
    Indio, CA
    417
    Re: Apple CarPlay for older 405's
    Quote Originally Posted by DJJ View Post
    Please message me as soon as you have this all working and can do a video demo! I am very interested in this route for my 2015. I am interested this running in carplay only and also curious how this would affect the SAT radio that the current setup provides.
    CarPlay is confirmed...it's just an adapter that plugs into the USB from the android unit. Your radio functions also stay the same. I'll try to do a video soon.
    Attached Thumbnails Attached Thumbnails Alternate Replacement Head Units for older L405's-img_2466.jpg
    Ray
    Current:
    Previous:
  13. #116
    June 29th, 2010
    Indio, CA
    417
    Quote Originally Posted by mark1107 View Post
    Looks intriguing. I would love to see google maps with traffic on it come up. I might get one then.
    CarPlay with Google Maps...
    Attached Thumbnails Attached Thumbnails Alternate Replacement Head Units for older L405's-img_2563.jpg   Alternate Replacement Head Units for older L405's-img_2564.jpg
    Ray
    Current:
    Previous:
  14. #117
    June 29th, 2010
    Indio, CA
    417
    Pandora will look much better on the screen when Apple releases iOS 13 in the fall...
    Attached Thumbnails Attached Thumbnails Alternate Replacement Head Units for older L405's-img_2565.jpg
    Ray
    Current:
    Previous:
  15. #118
    January 28th, 2019
    UK
    44
    So the wireless part works exactly as expected for anywhere between 1 minute and 30 minutes then it crashes. I’m sure it’s just a software issue which they’ll resolve soon . For the moment I’m just plugging in via the pass through USB which works pretty well but I’m also experiencing crashes after maybe an hour.
    If you are buying a CarPlay adapter deffo get the wireless one so you have the option of both
    Si
  16. #119
    ans
    ans is offline
    June 19th, 2019
    7
    Android screen looks pretty cool! I have one installed in my X5 and now you got me thinking about putting it in 2015 HSE. Btw, any issues with phone quality calls as the screen's bluetooth is absolutely terrible due to poor microphone quality....I have been using the original car bluetooth for calls, however, sometimes the iphone switches to the box. Also, not sure with the wireless carplay dongle will cause more issues phone call quality (mine is wired connection). So, how is the phone call quality?
  17. #120
    June 29th, 2010
    Indio, CA
    417
    Quote Originally Posted by ans View Post
    I haven't used the bluetooth from the android screen...I'm still using the original bluetooth system in the vehicle because it works fine but the audio does switch to the android box sometimes. I'm not sure why that happens but it's easy to switch it back when that does happen so no big deal. I ordered the wireless CarPlay dongle but I haven't received it yet so I'm still using the wired CarPlay dongle. The Carplay dongle was very unstable at first but I learned that there was a software update that would help so I installed the software update and now it's much better but still not perfect. I'm sure they will release another software update soon and hopefully that will fix the bugs. The CarPlay has been a really nice feature whenever it's working properly and although everything is not perfect with the new android screen, I still would recommend this unit over the factory screen.
    Ray
    Current:
    Previous:
  1. Yellow relay, alternate source
    By bomana in forum Range Rover Mark II / P38
    Last Post: September 14th, 2012, 03:51 PM
  2. alternate PS pump 95 LWB - Chevy S10
    By Sapelo Rover in forum Range Rover Classic
    Last Post: July 12th, 2010, 08:42 PM
  3. Alternate Parts Source in Seattle - Autosport
    By bchriste in forum Range Rover Mark II / P38
    Last Post: October 26th, 2007, 10:32 AM
  4. Favorite Replacement Head Units
    By pvcmpd in forum Range Rover Mark II / P38
    Last Post: September 9th, 2006, 05:22 AM
  5. EASY WAY TO ADD AN IPOD TO CLARION HEAD UNITS!
    By 2000m5 in forum Range Rover Mark II / P38
    Last Post: January 20th, 2006, 09:04 PM
