L405 clunk in rear when accelerating from stop... - Page 2
Results 16 to 26 of 26
Thread: L405 clunk in rear when accelerating from stop...
    February 17th, 2017
    Cypress Texas - 2014 RRS V8
    31
    Re: L405 clunk in rear when accelerating from stop...
    TSB LTB00668 v2
    It looks to be a Baffle and they put an Insullation panel in the tank.
    SOPHOMORE ROVER W84IT's Avatar
    June 29th, 2010
    Indio, CA
    400
    Quote Originally Posted by tbarrow View Post
    TSB LTB00668 v2
    Thanks...I'll call to give this info to them tomorrow and see how it goes
    Ray
    Current:
    2013 Range Rover L405 (Fuji White with Almond Interior)
    Previous:
    2010 Range Rover L322 (Alaska White with Jet Interior)
    2005 Range Rover L322 (Zambezi Silver with Charcoal Interior)
    2004 Range Rover L322 (Adriatic Blue with Sand Interior)
    December 21st, 2018
    Boston, MA
    139
    I have the Passport from my RR. It outlines all models. California has an Emmissions warranty based on your wonderful government of 7yr 70k. Send me your email
    The 7/70 emissions warranty recently saved me with my 2015 Audi A8 4.0T. The turbos failed (a growing problem across numerous Audis with the 4.0T engine) at 68,800 miles with the car well beyond the factory 4/50 warranty. Dealer repair would have been in the neighborhood of $10k, but Rhode Island (where the car was initially sold) is a CARB state and thus the 7/70 emissions warranty was in effect, and the repair cost me nothing out of pocket (except for the cost of the tow truck to the dealership).
    2019 RRS SCV8 ATB L494, Indus Silver
    2017 Range Rover SCV8 L405, Scotia Gray (wife's car)
    June 29th, 2010
    Indio, CA
    400
    I spoke with the service manager today and he informed me that there was no TSB for my 2013 L405 addressing the fuel tank issue. Does Land Rover have to release a TSB in order for them to cover it under the California Emission Control System Warranty?
    Ray
    Current:
    Previous:
    June 29th, 2010
    Indio, CA
    400
    Quote Originally Posted by Jaguar27 View Post
    This is a long shot, but I remember a quite a while back that some were reporting the same problem, it was cause by fuel sloshing around in the Tank when it go below a certain level.
    It seems that you were right...I finally let the fuel level drop below half tank and I haven't heard/felt the clunk since. The tank is now near empty so my next move is to fill up and run it by the dealer to see if we can duplicate the clunk.
    Ray
    Current:
    Previous:
  8. #21
    September 29th, 2018
    long island, ny
    231
    This seems to explain your problem, at least when going over uneven surfaces. https://static.nhtsa.gov/odi/tsbs/20...36653-9999.pdf
    2019 Range Rover Sport HSE Dynamic
  9. #22
    February 17th, 2017
    31
    Quote Originally Posted by bill2019 View Post
    That is for the front of the vehicle.
  10. #23
    February 17th, 2017
    31
    Quote Originally Posted by W84IT View Post
    That TSB was for the L494, L405 all motors is what I was told.
  11. #24
    long island, ny
    231
    Yes I know that but it is still a possibility seeing that is due to the suspension system. it is not unheard of for it to be complained about in one area but have it happen in another. Just something to look at if they have no other way to go. Besides noises are hard to locate position so seeing that his description of the symptoms are very similar it should not be ruled out.
  12. #25
    May 17th, 2018
    Glenbrook, NV
    You don’t need a tsb from OE in order to file any warranty, emissions related or not. A tsb is an internal advisory system from OE to techs advising them of potential issues and the remedy, nothing more. A tsb is NOT a recall, although it can become a mandated recall if fail events become prominent.
    As for a fuel tank baffle coming loose inside tank, how exactly is this an emissions item? Is it causing an elevation in tailpipe emissions? If not, it is not an emissions related failure.
    The fix is likely a replacement of fuel tank, if in fact it is a baffle as it’s likely due to a weld failure.
  13. #26
    June 29th, 2010
    Indio, CA
    400
    Quote Originally Posted by Tahoemac64 View Post
    I'm not sure if the fuel tank baffle is an emissions item but the fuel tank is listed as one of the parts covered under the CA emissions warranty...
    Attached Thumbnails Attached Thumbnails L405 clunk in rear when accelerating from stop...-img_6644.jpg
    Ray
    Current:
    Previous:
  1. Clunk from rear when turning left and taking off from a stop
    By ooo5ad in forum Range Rover Mark III / L322
    Last Post: August 3rd, 2016, 04:51 PM
  2. Sounds like marbles from rear accelerating from stop only
    By joenyc in forum Range Rover Evoque / L538
    Last Post: February 5th, 2016, 08:24 PM
  3. Dash board warning: Stop the car, Stop safely, Stop engine
    By hjawang in forum Range Rover Sport / L320
    Last Post: March 16th, 2015, 06:11 AM
  4. small clunk when accelerating from a stop????
    By 2kRR in forum Range Rover Mark II / P38
    Last Post: April 18th, 2006, 04:45 AM
  5. "Clunk" from rear when starting from full stop
    By lunacie in forum Range Rover Mark II / P38
    Last Post: May 3rd, 2005, 04:47 PM
