2013 HSE Multiple fault codes BRAKE, HDC, Adap Dynam, Stabil
Results 1 to 10 of 10
Thread: 2013 HSE Multiple fault codes BRAKE, HDC, Adap Dynam, Stabil
    August 29th, 2016
    colorado
    13
    Hi,
    Wondering if anyone has ideas or advice for an issue that came up today on my 2013 RR HSE.
    I drove my car about 45 miles today and all was fine. Got back in my car to go home and multiple fault codes came on all at once. My car is driving fine, the fault codes are all solid amber color. It said "hit ok to clear" which I did and they went away until I turned my car off and started it up again 30 minutes later. All the same codes came back up immediately.
    The codes I am getting are"
    Stability Control Not Available, drive with care- amber solid light with triangle and exclamation mark
    BRAKE, Emergency brake assist not available- amber solid light
    Adaptive Dynamics fault- yellow solid light
    HDC not available System fault- amber solid light
    ABS, ABS fault- solid amber
    BRAKE, Parking brake fault- solid amber light
    All of these go away when I press ok on them.
    The lights at the very top of my dash do not go away and they are:
    The word 'BRAKE' with an amber Triangle & exclamation mark just below the word brake.
    A picture of car on winding road (at least this is what it looks like) that is an amber color.
    ABS with a snowflake above it is also amber.
    Thanks for any and all advice!
    December 21st, 2018
    Boston, MA
    116
    Re: 2013 HSE Multiple fault codes BRAKE, HDC, Adap Dynam, St
    Quote Originally Posted by doublea13 View Post
    Hi,
    Have you had the battery load checked? In Audis, when you get the christmas tree of lights and fault codes while the car seems to be operating OK, it's often an indicator of a dying battery.
    2019 RRS SCV8 ATB L494, Indus Silver
    2017 Range Rover SCV8 L405, Scotia Gray (wife's car)
    July 30th, 2007
    Chicago, Illinois
    386
    I agree with DW. I would replace the battery if it was me. It is a little bit of a pain because you need to remove the spare and loosen the air compressor in the boot in order to gain access.
    August 29th, 2016
    colorado
    13
    Thanks so much for the replies, gonna get the battery checked this week.
    August 29th, 2016
    colorado
    13
    Just wanted to update and see if anyone has advice:
    When the battery was checked it was at only 67% so I thought great, charge the battery and we'll be good to go.
    We charged it overnight and got it to 100%. When my husband took it out, all the same codes came back on (maybe they have to be cleared out?) but he also said that the power steering and antilock brakes weren't working properly and it was stuck in the low position (where usually you can't drive more than 15mph). When he got home I started it, was able to raise it to normal height with just a push of the switch and it drove normally (even though all the same fault codes were on).
    Took it on one more test drive. This time when I started it, it told me that it was in a lowered ride height, for safety. It also said that to override the lowered ride height to hold brake and button for 3 seconds, which I did, and it raised it up. It also kept saying to drive carefully as ride height was overridden. The steering was a bit stiffer, couldn't really tell anything with the brakes as I just drove through the neighborhood.
    Last thing, when the large round "auto" button is depressed it is usually lit up orange. There is no light on the "auto" right now. However, if I switch it from auto to another option (say low) the "options" all light up orange.
    So.... not really sure what is going on at this point
    December 21st, 2018
    Boston, MA
    116
    I wouldn't just "charge up" the battery, I'd replace it completely with a new one. The car is 5+ years old - is it still on the original battery?
    August 12th, 2015
    Toronto
    22
    FYI, I had a similar issue with my 2013, turned out to be a corroded main ground point in the front wheelwell. I would be tempted to say there is more of an issue than a simple battery replacement.
    August 29th, 2016
    colorado
    13
    Thanks for the added suggestions!
    I'll update when we find the underlying issue.
    June 5th, 2018
    135
    This sounds to me like a simple brake issue, like a defective parking brake light switch or a low brake fluid indication. Anytime a standard brake fault occurs, most stability or anti-lock system goes nuts. I would check the brake system basics first. Ray
    August 29th, 2016
    colorado
    13
    Hi, I apologize I didn't update sooner. The problem was a broken wire up in the front left wheel well. They spliced the wire together and all was immediately fixed.
  1. Multiple fault codes, Hazard lights flashing and won't start
    By swainee in forum Range Rover Sport / L320
    Last Post: January 7th, 2019, 08:22 AM
  2. HDC Fault System not available and multiple lights!
    By aussie77 in forum Range Rover Sport / L320
    Last Post: October 30th, 2017, 09:49 PM
  3. AFL Fault, ABS fault, HDC fault, TRS fault
    By Bailey1918 in forum Range Rover Mark III / L322
    Last Post: August 14th, 2015, 01:08 AM
  4. 2004 Range Rover P0021 and other multiple fault codes
    By Disco Rover in forum Range Rover Mark III / L322
    Last Post: October 31st, 2014, 10:17 AM
  5. Multiple Fault Codes....
    By Hemi in forum Range Rover Mark II / P38
    Last Post: June 18th, 2012, 12:22 AM
