Range Rover L322 (2005-2012) Lift Kit
Results 1 to 15 of 17
Thread: Range Rover L322 (2005-2012) Lift Kit
    Vendor JohnsonRods's Avatar
    May 30th, 2017
    Southern California
    50
    For your Range Rover L322 (2005-2012) we have a 2 inch lift kit. The lift will allow for a larger tire such as a 275-55-20 (31.9 inches). Check here for more examples with different size tires:
    Range Rover Lift Kits
    May 30th, 2017
    Southern California
    50
    Re: Range Rover L322 (2005-2012) Lift Kit
    Time to get ready for those summer trails and some new off road or larger tires.
    Here are some great examples of a L322 with a 2 inch Johnson Rod Lift.
    http://johnsonrods.com/johnson_rods_3_003.htm
    Range Rover L322 (2005-2012) Lift Kit-michael-wertin-275-70-18-33.2-inches-mickey-thompson-mtz.jpg
    May 30th, 2017
    Southern California
    50
    Check out our 2 inch Johnson Rod lift option for your 2005-2012 Range Rover L322:
    May 30th, 2017
    Southern California
    50
    L322 with 305-45-22 (32.8 inches). Owner did some work to fit these tires and has rub on turns
    I generally recommend being around 32 inches max.
    Range Rover L322 (2005-2012) Lift Kit-wade-herman-l322-305-45-22-32.8-inches-rock-star-2-wheels.jpg
    May 30th, 2017
    Southern California
    50
    Here is another L322 with 285-50-20 tires and a 2 inch Johnson Rod lift kit:
    Range Rover L322 (2005-2012) Lift Kit-ralph-herman-l322-285-50-20-cooper-discoverer-atp.jpg
    FRESHMAN ROVER Rovah's Avatar
    January 24th, 2013
    Ladue, MO
    133
    Although this is a nice kit, personally 2” is not enough lift for my taste on my L322. Any higher lift kit in the work?
    2005 RR HSE 4.4 Java Black
    2004 RR HSE 4.4 Zambezi Silver
    May 30th, 2017
    Southern California
    50
    Two inch is the max you can go with the air suspension.
    This seems to be the best option that will allow a 32 inch tire such as a 275-55-20.
    January 24th, 2013
    Ladue, MO
    133
    Quote Originally Posted by JohnsonRods View Post
    are you implying that with the lift kit, one could still use the 3 stages of the suspension ride with no problem at all?
    Moderator RRToadHall's Avatar
    27,583
    That is exactly what he is saying. The limitations of the EAS bladders is well documented in the L322 section. It boils down to there only being so much rubber there.
    ~ Maharishi Mahesh Yogi~
    May 30th, 2017
    Southern California
    50
    Here is a L322 with 33 inch tires and a 2 inch Johnson Rod lift kit.
    20x9.5 ET45 Stormer’s
    Goodyear Wrangler Duratrac 275/60/20
    Build by Stewards Automotive
    This did require some modification.
    For a larger tire with no modification go with a 275-50-20
    Lift kit info here: http://johnsonrods.com/johnson_rods_3_003.htm
    Check our blog site. If you have a lift kit installed send us a picture:
    https://johnsonrods.wordpress.com/
    Matthew McCormick L322 33's 275-60-20 20x9.5 ET45 Stormers with DuraTracs.JPG
    February 13th, 2018
    Las Vegas, NV
    Ive looked on your webpage and wonder if you make the same lift kit for the 2003 HSE. I see that your lift kit is only available for the 2005-2012.
    May 30th, 2017
    Southern California
    50
    No, they don't fit the earlier models, just 2005-2012 for the L322.
    Did you know that you can get 18" Compo wheels for your L322 so long as its not a supercharged model?
    Range Rover L322 (2005-2012) Lift Kit-steven-brady-l322-305-45-22-auturo-trail-blade-description-process.jpg
    May 30th, 2017
    Southern California
    50
    Check out this lifted L322 with 34's (275-65-20) Plastic cut and windshield wiper system relocated.
    Built by Wheel Tech Tuning, Glendale CA
    Check out our lift kit here: http://johnsonrods.com/johnson_rods_3_003.htm
    May 30th, 2017
    Southern California
    50
    Check out this Range Rover L322 with 32.5 inch tires and a 2 inch lift kit, 30 mm spacers.
    Get yours here: http://johnsonrods.com/johnson_rods_3_003.htm
    May 30th, 2017
    Southern California
    50
    Time to get off road with a 2 inch lift kit from Johnson Rods and some larger off road tires.
    Visit our website for more details and to order. http://johnsonrods.com/johnson_rods_3_003.htm
    Also, check out our blog site to leave a comment:
  1. L322 Range Rover Inspection 09.2005
    By LA Dawg in forum Range Rover Mark III / L322
    Last Post: October 18th, 2016, 08:33 PM
  2. lifting a range rover with a dodge lift kit
    By bryceandrews in forum Range Rover Classic
    Last Post: September 12th, 2012, 08:25 PM
