Playing in the new toy... - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Thread: Playing in the new toy...
  1. #31
    JACK'S GRANDAD leftlanetruckin's Avatar
    August 26th, 2007
    9,029
    Re: Playing in the new toy...
    Seeing as I plan on 35's for the DII, it was upgrade axle time.
    Yeah, I could have got off the shelf stuff, for @$3500!!! HD axle shafts, regear, lockers. That's nuts.
    Picked up a pair of FJ80 axles last year. Correct drop for the DII, full float rear axle, strong enough for 35's all day, stock 4.10 gears, selectable lockers front and rear, tons of aftermarket support from more than one vendor. All told, $1800 for the pair with wiring harness, radius arms, etc.
    Ground off all the brackets after some measuring, nothing would line up, oh well.
    Going to go triangulated 4 link in the rear, triangulated radius arms and a panhard bar up front. Simple, proven, easy to build strong.
    While waiting for parts, I made the truss for the rear axle. The upper link arms will weld to the top of it, and I needed a stronger foundation than just the diff housing (not to mention it's offset).
    Slightly overbuilt, using 3x2x1/4"wall box section, then plated the ends with 1/4" sheet.
    '11 L322 SC
    '04 DiscoII - wheeling rig
  3. #32
    LR1
    LR1 is offline
    JUNIOR ROVER LR1's Avatar
    December 28th, 2008
    Louisiana
    622
    Martin - looking good on the welding. I'm jealous. Something I've always wanted to lean. Maybe one day. Wm
    '71 SERIES III
    MULTIPLE D90'S
    '04 RR
    '05 LR3
    '10 RR
    '17 RR
    '18 Range Rover V8 Supercharged - (SOLD, Whew.... MORE PROBLEMS THAN THE 2017)
    '18 TOYOTA LAND CRUISER
  4. #33
    FRESHMAN ROVER burninator's Avatar
    January 22nd, 2013
    Denver, CO
    95
    I always love your builds, Martin. Please come wheel with us in Colorado sometime.
    2000 Range Rover Supercharged - 1999 Range Rover 4.6 HSE - 2003 Discovery S - 1993 Mustang LX 5.0 Coupe - 2016 Fiesta ST
  6. #34
    August 26th, 2007
    9,029
    Guess I dropped the ball and forgot to update this!
    The rear is 4 linked with +2" OME coils and adjusted upper and lower coil mounts.
    Front is SOA with XJ OME leafs. After measuring and measuring, no easy way to get the front done with links. So SOA it was.
    Grabbed a set of 6 lug 17's with half worn 35's on them for mock up. It will be getting 37's once everything is settled.
    Got the Ypta lockers all wired in with the Toyota ECM and switch. Took some figuring,but it works perfectly. Also wired in a Truspeed module to set the speedo using the FJ80 ABS sensors.
    Few pics.
    Front end. Forward from stock @3"
    Corner shot on 35's
    Spot the Toyota locker switch and the 2 LED lights
    Rear end. Be trimming the bumper to suit. Further back @3" to center it up. Wheelbase is now 106"
    Reused the coil mounts, moved them back and down, then gusseted them. Also made some dislocation cones and lower retaining plates
    '11 L322 SC
  7. #35
    February 25th, 2018
    Charleston, South Carolina U.S.A.
    97
    Very nice work leftlanetruckin!
    2011 Range Rover HSE (Santorini Black, Jet Leather/Interior, Ivory Headlining)
  8. #36
    August 26th, 2007
    9,029
    Thanks!
    '11 L322 SC
  9. #37
    SOPHOMORE ROVER YooperP38's Avatar
    December 13th, 2011
    Sault Sainte Marie, Michigan
    344
    Looks great Martin! I do have to say I am little bummed you went with leaves up front, but you have to do what is necessary to get the job done.
    2001 4.6 HSE java black (mine, all mine)
    2004 Jeep Grand Cherokee WJ (wife's driver)
    1986 Toyota pickup (mud racer, getting a 600hp LQ9 swap)
    http://www.becmdoctor.com
  10. #38
    August 26th, 2007
    9,029
    I've wheeled SOA rigs in the past with fantastic results. Days before everyone went 4 link etc....lol
    Funny how we forget how good some of the older stuff was, isnt it?
    I can radius arm it if there are issues, but this got it done a lot quicker while spreading the load more evenly. We'l see how it does.
    Winch is in and nicely tucked away.
    Bilstein 5125's are on in the front, as well as pinion angle etc set.
    Ream out the 'Yota for 1 ton TRE's tomorrow then get the steering and panhard bar all buttoned up
    '11 L322 SC
  11. #39
    August 26th, 2007
    9,029
    One ton steering all done. Had to put a 18 degree bend in the draglink, but will have hydro assist so no big deal. The tubing for the tie rod, drag link and panhard bar is all 1.5" .250 wall DOM, so plenty strong.
    Tires got here today, o got them put on the wheels I sanded and painted to see what needs trimming. Front fenders and rear bumper is the answer! lol
    '11 L322 SC
  1. WOW 30,000 Toy Cars?! Check Out The World's Largest Toy Collection!
    By AutoGuide.com in forum RangeRovers.net General Discussion
    Last Post: May 2nd, 2014, 12:04 PM
  2. New toy coming in....
    By leftlanetruckin in forum General Chatter
    Last Post: August 3rd, 2012, 09:47 AM
  3. Possible new Toy - thoughts?
    By PJPR01 in forum Range Rover Sport / L320
    Last Post: April 6th, 2009, 08:09 AM
  4. My toy RangeRover
    By kin in forum Range Rover Mark III / L322
    Last Post: January 10th, 2009, 03:28 AM
  5. New off road toy
    By v8kenny in forum Range Rover Classic
    Last Post: April 15th, 2008, 02:18 PM
