Playing in the new toy... - Page 2
Results 16 to 30 of 39
Thread: Playing in the new toy...
    JACK'S GRANDAD leftlanetruckin's Avatar
    August 26th, 2007
    9,077
    Re: Playing in the new toy...
    They are called "rock sliders" really.
    They protect the door sills when they get hung on a rock etc. Also used as a jacking point.
    '11 L322 SC
    '04 DiscoII - wheeling rig
    August 26th, 2007
    9,077
    Flapper wheel all the radius', and then the front will be ready for paint tomorrow.
    That will be both bumpers and rock sliders done. Under $500 in materials.
    '11 L322 SC
    August 26th, 2007
    9,077
    Job done, for now.
    Will be recessing some small round lights into it, as well as trimming it for the new tires when they go on.
    Heading back to work, so no time for more stuff right now!
    '11 L322 SC
    FRESHMAN ROVER Cabover1000's Avatar
    December 22nd, 2015
    Belding, MI
    100
    Quote Originally Posted by leftlanetruckin View Post
    Job done, for now.
    Click image for larger version.
Name:	front bumper4.jpg
    Great job! I wish you were closer to me, I would definitely have you build me my rear bumper for me. I built my front on and it looks ok but the rear looks like it may be a Playing in the new toy...-imageuploadedbyag-free1457945611.118185.jpgpain.
    Sent from AutoGuide.com Free App
    August 26th, 2007
    9,077
    Here is the rear bumper I made for P38's
    '11 L322 SC
  8. #21
    December 22nd, 2015
    Belding, MI
    100
Name:	rear bumper.jpg
    That looks great. ill have to try to make something similar for my rear bumper.
  9. #22
    August 26th, 2007
    9,077
    Think I made a thread about them, when I made them.
    The clevis' are 3"x1" solid stock, and go into the mounts that go into the frame rails....Solid.
    I bent a piece of 1.75" DOM tubing for over the winch tray and welded it on today. Cheryl wanted a hoop, so on it went. Wish I had some thinner walled seamed tubing..... 0.188 wall DOM is a little overkill for a hoop on a bumper!
    '11 L322 SC
  10. #23
    August 26th, 2007
    9,077
    Well got home again, and decided to make a washer bottle for the windshield, rear window and headlamp washers. Couldn't relocate the existing one due to the SAI pump, so off I went.
    Just used what I had paying around.....
    The end result, tucked behind the winch mount of the bumper I made.....
    Not worked out the capacity, but considering I had NONE, it's a bonus. Would guess @a gallon or so...
    '11 L322 SC
  11. #24
    August 26th, 2007
    9,077
    Long term for the Disco...
    I have a line on a pair of Yota FJ80 axles, already factory geared to 4.10 and equipped with selectable lockers. They are the correct drop and width for the DII. A speedo adjuster to make the ABS signals play nice withe the DII, and new driveshafts.
    I could get the Rover ones regeared and locked, but at @$3500 to get hardened axle shafts, 2 new 3rds with ARB's, it's not cheap. They Yota axles are $1800 in comparison, and will handle 35's no problem.
    Figuring I will put custom radius arms on it for a while, see how it does with them. Can adjust pinion etc that way. Will do them out of thick walled 2" square tubing, using the factory mounts on the frame.
    @3" of OME lift and trimmed fenders, then 35's.
    Winch up front, go wheeling.
    '11 L322 SC
  12. #25
    November 10th, 2011
    Maine
    81
    I like the rear bumpers you're building, do you sell them or just build the, for yourself?
    89 RRC - 2" TerraFrima Lift, RTE Bumper, Warn 9.5ti, 32" GY MTRs
    08 LR3 SE - 50mm IID lift, 265/65/18 Toyo Open Country AT2's
    08 RR SPORT HSE LUX w/ 2010 19" wheels
  13. #26
    August 26th, 2007
    9,077
    Used to sell the stuff for P38's, but then got stuck with a bumper for over a year. I'll do one off stuff now, but that's it. Same for motors, I wont get stuck with a fully rebuilt engine again neither.
    Too many folks that think their bank account is bigger than it really is, and say "Yes" to stuff before asking their wife/mummy/daddy.
    Then there is the "why does it cost that much" crowd. Last time they built anything, was either 30 years ago out of scrap steel, or it was such a hack job I wouldn't put my dog's name to it. Yep, seen it in person......Not pretty.
    Currently have 494 and 405 guys asking about sliders etc. though, so we'll see where that goes.
    '11 L322 SC
  14. #27
    SOPHOMORE ROVER YooperP38's Avatar
    December 13th, 2011
    Sault Sainte Marie, Michigan
    347
    Martin,
    You can take me off the list. Sorry. But the good news is I bought a welder and I am getting pretty good with it, so I'm building my own. I like your Disco and I want to come wheeling with you, my p38 is going strong.
    Eric
    2001 4.6 HSE java black (mine, all mine)
    2004 Jeep Grand Cherokee WJ (wife's driver)
    http://www.becmdoctor.com
  15. #28
    August 26th, 2007
    9,077
    No problem Eric.
    We play around here in Fulton on some weekends, but there is nothing extreme there.
    SMORR is a great place to go, so I'll give you as much notice as possible next trip
    '11 L322 SC
  16. #29
    December 13th, 2011
    347
    Looks like I will need about 24 hrs. notice. Of course some sort of 48 hr sleeping pill for the wife would help too. Keep me informed, it would be nice to wheel with some other Rovers for a change.
  17. #30
    August 26th, 2007
    9,077
    LOL on the wife!
    Sounds good to me.
    We can go play in Fulton anytime, it's 15 minutes from me.
    SMORR is a great park though, and isn't too awfully far.
    Asked for a price for some HD axle shafts, and regeared ARB'd third members. Toyota axles didnt work out this time round.
    Then I'll sort the lift out. Looking at 3" of OME lift, cut out fender flares, and trimming to get the 35's on there!
    '11 L322 SC
  1. WOW 30,000 Toy Cars?! Check Out The World's Largest Toy Collection!
    By AutoGuide.com in forum RangeRovers.net General Discussion
    Last Post: May 2nd, 2014, 12:04 PM
  2. New toy coming in....
    By leftlanetruckin in forum General Chatter
    Last Post: August 3rd, 2012, 09:47 AM
  3. Possible new Toy - thoughts?
    By PJPR01 in forum Range Rover Sport / L320
    Last Post: April 6th, 2009, 08:09 AM
  4. My toy RangeRover
    By kin in forum Range Rover Mark III / L322
    Last Post: January 10th, 2009, 03:28 AM
  5. New off road toy
    By v8kenny in forum Range Rover Classic
    Last Post: April 15th, 2008, 02:18 PM
