SRS light came on cheapest tester to turn it off
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: SRS light came on cheapest tester to turn it off
    SOPHOMORE ROVER xrav22's Avatar
    December 15th, 2014
    Southern Ca.
    335
    Hi SRS light came on cheapest tester to turn it off.
    I have looked all over but cannot find out which tester will in fact read the fault reason and let me
    turn off the light. Anyone actually have a model number they own and know will do this.
    Thx
    1997 Range Rover 4.6 HSE
    1985 Chevy Corvette 5.7 TPI
    4x SrS reset with nano
    P0183 changed fuel temp sensor OK
    P1179 cleaned maf with maf cleaner OK
    P1314 reset CEL OK (was going thru large puddles when CEL went on).
    Service Engine reset/Adaptive values reset
    LEGACY VENDOR Scotty's Avatar
    March 21st, 2009
    2,064
    Re: SRS light came on cheapest tester to turn it off
    where are ya in SoCal? P.M. Me
    Scotty, head womble ~ "Make Good Use of Bad Rubbish."
    1963 Series II A 88 Under going complete Restoration
    1996 Rangie; Milk Wagon Top Hat Motor completely rebuilt
    1999 Rangie; Callaway Epson Green completely Rebuilt
    2002 Rangie; Black on Black Restored to Original Condition
    December 15th, 2014
    Southern Ca.
    335
    Anyone have any scanner models still looking.
    Moderator RRToadHall's Avatar
    27,543
    Quote Originally Posted by xrav22 View Post
    Did you PM SCOTTY as noted in the post above yours?
    ~ Maharishi Mahesh Yogi~
    December 15th, 2014
    Southern Ca.
    335
    Hey I did but he offered to turn out the light (75 miles each way) but I would like to have a descent scanner.
    I cant fiqure which model will work with 97 RR.
    Banned
    March 31st, 2014
    Peterborough, UK
    3,952
    Nanocom Evolution. But at US fuel prices, it would be far cheaper to do a 150 mile round trip......
    Alternatively, fix whatever it is that has caused the SRS light to come on in the first place.
    March 21st, 2009
    2,064
    I will tell ya, sometimes it make sense to take a drive and see what toys other P38 owners have. But that's just me yo..
    27,543
    We have an entire forum section dedicated to diagnostic gear and P38 coverage has been covered ad nauseum. An afternoon with Scotty will enlighten you far more than weeks or months of casual reading.
    December 15th, 2014
    Southern Ca.
    335
    Thx its more like 110 each way, but I would like to read the fault to fix it. If it was a fault I caused or a glitch,
    I would expect the light to stay off. From my research on the 97 after fixing you still to reset the light, not until
    around 2002 did the srs system check itself on every start.
    Premium Member Nico3687's Avatar
    November 1st, 2013
    So Cal. + Vermont
    785
    Have you checked the relay under the driver's seat to see if it's tightly connected? I literally JUST read about a '99 P38 owner that had his SRS light come on because the relay was not clicked all the way into place.
    '99 Range Rover 4.0 SE, Bosch (Epsom / Walnut)
    '07 Range Rover Supercharged (Zermatt / Jet)
    '17 Jaguar F-Type R coupe (Storm Grey / Red)
    27,543
    Relay? The only relay under a driver's 97 seat that I can think of would be the EAS. Usually with late 99/Bosch and up it's the SRS connector under the seat that comes disconnected... not found on a 97.
    December 15th, 2014
    Southern Ca.
    335
    I found this but nothing to plug into. I think it comes out of the yellow harness. No shops around can give me a code. No way to reset it manually, wow.
    Attached Thumbnails Attached Thumbnails SRS light came on cheapest tester to turn it off-wp_20150317_001.jpg
    November 1st, 2013
    So Cal. + Vermont
    785
    Yes the SRS connector is what I was referring to; I wasn't aware that it only exists on the Boschs.
    December 15th, 2014
    Southern Ca.
    335
    Thx for the ideas I did not know about the diagnostic threads. I decided to go with Icarsoft 930i
    hoping for the same results as this gent.
    https://www.rangerovers.net/forum/12-...-6-1998-a.html
    Banned
    March 10th, 2014
    208
    Yes 'early' US rigs are a bit 'quirky' when it comes to SRS - as you (probably !) still have the individual crash sensors on the front chassis beam (?) If so you are absolutely correct that if you re-set it but the fault condition remains then the SRS light illuminates again, ie. just finding/fixing the fault is not enough in itself.
    The SRS protocols that these rigs use are also a bit 'quirky' so I hope your i930Carsoft works out OK too. If it does it was a great investment: Folks charge maybe $50/pop to re-set the light... (Not Scotty though, he is a 'gent' !)
  1. Srs light on
    By Tes in forum Range Rover Classic
    Last Post: November 14th, 2017, 05:50 AM
  2. Srs light
    Last Post: December 3rd, 2014, 12:31 PM
  3. srs light
    By cfix85 in forum Range Rover Mark II / P38
    Last Post: August 14th, 2012, 04:33 AM
  4. ? on SRS light
    By brad s1 in forum Range Rover Mark III / L322
    Last Post: October 11th, 2010, 12:02 PM
  5. SRS light flashing and AIRBAG FAILURE light on gauge display
    By amoking in forum Range Rover Mark II / P38
    Last Post: August 24th, 2006, 05:20 PM
