Welcome to RangeRovers.net
Range Rover Model Specific Technical Forums
RangeRovers.net General Discussion
RangeRovers.net For Sale / Wanted
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
Range Rovers Wiki
Range Rovers Wiki & Owners Guide
An Introduction To Range Rovers
Latest Posts
'04 RR HSE - started diving into the ole' HDC Inactive/Air Suspension Inactive/ABS Faults issue. Started with replacing the front speed sensors. Passenger side wasn't bad, but driver's side has a couple wires that are not plugged into anything. The first one appears as if it goes to a brake pad...5 replies 198 views
I’m in here, obviously I’m having issues. The rover starts and drives fine for 15 to 20 minutes on the first start of the day. When I slow down and come to a stop, it stall out. It fires back up fine and drives until the next stop or two. It never stalls on the highway. I don’t think it’s a...4 replies 80 views
Hello, ive just bought a p38 with neutralized BW 44-62-003TCase. Reason i know this, is beceause Gearbox is set to drive (nothing happens, just engine revving) and then i set it to park, there is a ratcheting soound , letting me know it was spinning. Long story short, previous owner rode the...3 replies 76 views
My EAS is acting like it has the front left and rear right wiring backwards - it’s driving down the road lowering one instead of the other. I’ve got a new driver pack, genuine height sensors, new ECU and cleaned up the lock panel connectors it still does this. what can I look at next?5 replies 108 views
as you can see from this picture the middle portion of the screen is starting to yellow is this fixable or we need to replace the screen. Why is the door handle on the drivers door doing this one end is also coming out?? Can I remove this trim panel and paint it? Thanks23 replies 404 views
