Direct link to Edmunds.com Land Rover/Range Rover Info, RR Sport prices, quotes, reviews
LED lighting for license frame
The technical forum for the P38a/second generation Range Rover 1995-2002
Moderators: Tim (Scotland), Ka177ran, paul.adshead
Postby tjh2dUVA » Mon Jan 05, 2009 7:07 pm
Sorry if this has been addressed before, but I couldn't find anything relevant in the search topics -- at least under the P38 category.
Has anyone retrofitted LED's for the small bulbs that illuminate the license frame in the back underneath the trunk section? It would seem like a fairly easy swap, and it makes a pretty nice difference from what I have seen on other vehicles.
Thanks.
2002 Range Rover 4.6 HSE
2008 Range Rover SC
tjh2dUVA
Re: LED lighting for license frame
Postby rrtoadhall » Mon Jan 05, 2009 7:34 pm
A member has an active topic over on teh MarkIII board on this right now.
Pâté is passé. Caviar is so 1980s.
Unicorn is the sparkling, crunchy, savory meat of today's elite.
Unicorn - the new white meat.
User avatar
rrtoadhall
Deputy Admin
Postby p38arover » Mon Jan 05, 2009 9:41 pm
I think it will bring up a bulb failure alarm. That's why mine are taped over with black electrical tape - the number plate is on the rear bar and not on the tailgate as it would be obscured by the spare wheel carrier if left in the original position.
Ron Beckett
1995 Range Rover HSE 4.6 V8 auto
2007 Yamaha XJR1300
2006 Suzuki DL650 V-Strom
RIP Bucko (1979-2007) Riding on forever
User avatar
p38arover
Deputy Admin
Postby q-rover » Tue Jan 06, 2009 12:23 am
I did it with all my lights. :D
Unfortunately as P38rover says you get bulbfailure alarm, so I changed
them back again, except for the rear numberplate ones and interior. I dodn't
mind the alarm too much, it's offset by the bright white cones of light
rather than a dull glow.
I was thinking of doing the puddle lights in the doors as well, but can't get the
damn things out. :x
For the interior I went with an amber colour. The amount of light is very good
from the LED's I got and you don't ruin your 'nightvision', plus they complement
the tan leather I have.
1998 Autobiography 4.6 V8 of course
User avatar
q-rover
Solihull Member
Postby tjh2dUVA » Tue Jan 06, 2009 7:57 am
Well I went ahead and ordered a pair -- they were really cheap, so I might as well test it out.
There has got to be someway to either disable the bulb failure alarm or get some kind of special resistor that won't trip it.
2008 Range Rover SC
tjh2dUVA
Postby p38arover » Tue Jan 06, 2009 9:01 am
tjh2dUVA wrote:There has got to be someway to either disable the bulb failure alarm or get some kind of special resistor that won't trip it.
No. The bulb failure alarm appears to work by monitoring current drawn. A LED has less draw so it will look like a failed bulb. To overcome that you will need to put a low-value resistor in parallel with the bulb so it draws more current. The cheapest low value resistor that will handle the current without overheating would be a....... bulb.
Ron Beckett
2007 Yamaha XJR1300
User avatar
p38arover
Deputy Admin
Postby tjh2dUVA » Fri Jan 09, 2009 4:45 pm
The LED bulbs came in the mail a few days ago and I hooked them up. The install was fairly straight forward. The only issue was that the bulbs themselves have about 9 mini LED bulbs in them. The entire bulb housing was just slightly too large to fit in the factory casing hole, so I had to kind of rig it into place with some electrical tape. At any rate, they look much better. They are super bright, white lights. The beam can even be seen on the ground. It is a night and day difference between the crappy tungsten ones. I have had them in for several days now and have had no Bulb Failure warnings. I have turned the lights on and off numerous times to see if I could trip it, and nothing. These lights may not be wired to alert for failures. If anyone else is interested, the lights I got were JDM T15 xenon white LED 2825.
Sorry for the poor image quality. Even with my sub-par photography skills, you can immediately tell a big difference.
Thanks.
2008 Range Rover SC
tjh2dUVA
Postby p38arover » Fri Jan 09, 2009 5:07 pm
The lamps you bought obviously draw enough current for the system to not detect a bulb failure.
I do have to ask, though, why do you want your number plate brilliantly lit?
Ron Beckett
2007 Yamaha XJR1300
User avatar
p38arover
Deputy Admin
Postby tjh2dUVA » Fri Jan 09, 2009 10:09 pm
Well it's not that I want my license plate brilliantly lit, I just can't stand the burnt amber color of the light produced by the tungsten bulbs.
It's purely an aesthetic thing, most likely due to owning a newer Rover with the crisp white/blue light band produced by xenon bulbs. I just like the color of light better.
If I can figure out a way to turn on my fog lights independent of having the headlights on, I want to swap out at the H3 bulbs for some high-powered SMD LED panels. Due to their longevity, they can be used as daytime running lights and produce a virtually equivalent light color as true HID xenons. Since the fog lamps have a clear lens where bulb shines through, it would seem to be viable option, unlike the main beams which have the casing with prisms for halogen bulbs.
2008 Range Rover SC
tjh2dUVA
Postby BeanBean » Sun Jan 11, 2009 2:23 pm
I like the look. You have me in the market for some LEDs now. :clap:
User avatar
BeanBean
Postby Hoges » Sun Jan 11, 2009 4:04 pm
The answer relates to matters "in camera" .... :shock: :lol: :lol: :lol:
Hoges
99 HSE4.6 (Bosch)
Hoges
Postby p38arover » Sun Jan 11, 2009 8:35 pm
That's why mine is barely legal - maybe it's not even that.
Ron Beckett
2007 Yamaha XJR1300
User avatar
p38arover
Deputy Admin
Postby 99p38a » Wed Jan 14, 2009 8:16 am
I don't think that the license plate lights are set to the bulb failure warning. Unless if only 1 of the 2 is blown it still draws enough for the failure not to warn. I found this out when I had my car taken for inspection. The shop charged me $4 for the bulb and $10 to put the bulb in. Only 1 blown, couldn't convince them to let me out since it still has one. All else was great.
Brian
99 Bosch Range Rover HSE
Long Island, NY
User avatar
99p38a
Postby wills » Thu Jan 15, 2009 5:43 pm
q-rover wrote:I was thinking of doing the puddle lights in the doors as well, but can't get the damn things out. :x
After reading this thread I started wondering about putting LED bulbs in my puddle lights too - I got hold of 2 from Halfords (UK parts store place) for a ridiculous price of £9.72p just as a little experiment.
Got home and put them in and the difference was amazing, the ground is very well lit when opening a door now whereas before I sometimes couldn't even tell I had puddle lights!
I have since done a bit of research on-line and found the Ultraleds.co.uk do some interesting LED bulbs for cars at a more reasonable price so have ordered a few as more of an experiment to see what those bulbs are like - they even do bulbs for the dash etc (the little wedge base one) AND they do ones which would fit the HeVAC unit (im not going for blue colours or anything, just the original green colour). As said, I have some on order so will post back with results, they will probably look awful :lol:
Lastly, to get the puddle lights out, get a small flat blade screwdriver, like a jewellers one and push it into the edge of the lens on the puddle light, push hard and the screwdriver will slot in between the lens and the rubbery plastic housing of the light. Once in, lever the lens out and then that will allow you to squeeze the body of the puddle light itself on different sides so you can pull it out of its hole. Took me a few mins to get the first one out but once you get the technique its easy, I had the other side changed in less than a minute!
-Wills :)
98 Range Rover 2.5 DSE Auto
Faultmate MSV
User avatar
wills
Postby p38arover » Sun Jan 18, 2009 3:26 am
99p38a wrote:I don't think that the license plate lights are set to the bulb failure warning. Unless if only 1 of the 2 is blown it still draws enough for the failure not to warn.
But you are right, A single bulb failure won't bring up the warning. I tried it tonight.
Ron Beckett
2007 Yamaha XJR1300
User avatar
p38arover
Deputy Admin
Next
Return to Range Rover P38A Forum
Who is online
Users browsing this forum: BlackSabbath, MSN [Bot], Three Phase and 7 guests
