2011 Range Rover service required Reset ???
Results 1 to 3 of 3
Thread: 2011 Range Rover service required Reset ???
    December 27th, 2012
    USA
    I have 30 K on 2011 Range Rover sport service required light seems to say on longer than usual can you reset this? I just changed my oil myself.
    December 18th, 2010
    59
    Re: 2011 Range Rover service required Reset ???
    cant reset it except at the dealer but it does eventually go away.
    November 18th, 2012
    Maryland
    71
    Quote Originally Posted by Ted Pleasant View Post
    Havent tried this myself..but found this here on the forum:
    http://www.oilreset.com/index.php?mf...ge+Rover+Sport
    2008-2012
    Land Rover recommends the use of a reset tool.
    Manual Reset Procedure:
    1. Press and hold the trip reset button.
    2. Turn the ignition switch on to the ignition position II (one position before starting engine).
    3. If the SII (Service Indicator Interval) function is enabled the information display will flash 'SERVICE' for 5 seconds and then display 'SERVICE' constantly. If the SII function is not enabled the information display will show the normal odometer and trip information.
    "4. If the trip reset button is released within 10 seconds of entering the reset mode
    "5. If the oil service value is to be reset
    6. If the trip reset button is pressed for 5 seconds the display will exit the reset routine.
    "7. If the trip reset button is not pressed for more than 10 seconds
    8. Turn the ignition off and then start the engine to verify the indicator has been reset.
  1. Late Model Range Rover Wheels, What Lugs Are Required?
    By Y-N-W-A in forum Range Rover Mark III / L322
    Last Post: August 3rd, 2012, 02:03 PM
  2. Range Rover Vogue 2007 TDV8 SIA Service Light Reset
    By halenko in forum Range Rover Mark III / L322
    Last Post: December 31st, 2009, 05:37 AM
  3. Range rover engine number guru required
    By peter-sherman in forum Range Rover Mark II / P38
    Last Post: March 4th, 2009, 03:44 AM
  4. 2006 Range Rover Service indicator reset
    By logiedurno in forum Range Rover Mark III / L322
    Last Post: August 29th, 2008, 06:26 AM
  5. Service garage required near Reading UK
    By Othillo in forum Range Rover Mark II / P38
    Last Post: January 9th, 2008, 02:39 PM
